Plumbing & Plumbers Forum - Wood Boiler Pre Heat Tank
Discuss Wood Boiler Pre Heat Tank at UK Plumbers Forums; I am looking to add a pre-heat tank to my existing setup which is a Daikin Altherma ASHP (EKHBH016A). I have attached a diagram and was looking for some advice ...
    Mar 2014
    Default Wood Boiler Pre Heat Tank
    I am looking to add a pre-heat tank to my existing setup which is a Daikin Altherma ASHP (EKHBH016A). I have attached a diagram and was looking for some advice to see if the proposed setup would work considering the heights and distances involved.Wood Boiler Pre Heat Tank-20160718_221838.jpg
    The wood boiler is a snowdon 30 multifuel boiler (30kw)
    The secondary storage tank is quite a distance away (22m) and situated in a basement 2 meters below the wood boiler.
    Comments would be appreciated.
    Thanks,
    9,981
    Default Re: Wood Boiler Pre Heat Tank
    are you hetas registered? if not you cant do the work
    Member Worcester's Avatar
    Jun 2011
    973
    NO, for lots of reasons! As well as Shaun's comments
    Also based on your sketch, I am afraid that we won't be able to give advice because of the possible dangers. You need to employ a qualified professional that is appropriately certified in solid fuel (not exclusively HETAS, there are others ) as well as heat pumps.
    Ther aren't actually many of those people about - what's your postcode?
  1. Replies: 6
    Last Post: 18-05-2016, 05:24 PM
  2. wood chip boiler
    By jcb in forum New Member Introductions
    Last Post: 28-09-2014, 03:02 PM
  3. Replies: 16
    Last Post: 08-04-2014, 11:12 PM
  4. wood stove back boiler/gas boiler
    By spycatcher in forum Plumbing Forum
    Last Post: 14-02-2014, 11:05 PM
  5. Heat bank (thermal store) linked to wood burning boiler. Engineer needed.
    By scruffders in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 09-01-2013, 09:14 PM
