Results 1 to 12 of 20
Plumbing & Plumbers Forum - Heat pump low pressure
Like Tree3Likes
Discuss Heat pump low pressure at UK Plumbers Forums; Hi all After checking jobs for the week I see the office have booked me in to a customer who has a Danfoss DHP-AX heat pump. She has had ongoing ...
    Feb 2016
    102
    Default Heat pump low pressure
    Hi all
    After checking jobs for the week I see the office have booked me in to a customer who has a Danfoss DHP-AX heat pump. She has had ongoing problems with the unit cutting out and displaying 'low pressure' error. Another company has tried to fix (only info is - replaced filters, altered pipework etc) and no further to resolving fault. She did mention to her knowledge they have not checked the external unit...
    My experience with heat pumps is limited and I don't do the refrigeration side. We have an air con engineer on firm who can check the refrige side. I am just wondering if anyone has come across this problem before? Am I right in thinking it would be better suited for the air con engineer to attend and check refrige pressures, low pressure switch etc. Or is there an external factor that can influence this issue that I can check i.e flow problems?
    I don't like going out to heat pumps with not doing refrigeration as it seems you can only do half a job.
    Thanks Jason
    Mar 2016
    48
    Default Re: Heat pump low pressure
    Low pressure trips can be a number of faults, has it been like this ever since it was installed? If so, is it correctly positioned?
    If the fault is intermittent, it is not likely to be a loss of refrigerant gas as it would be constantly tripping out. Any other fault symptoms accompanying the low pressure trips?
  3. The Following User Says Thank You to Leezygeezer For This Useful Post:
    Feb 2016
    102
    Have not been to site yet so unsure of any other symptoms or history.
    Only info i have is from an email 'I have a danfoss DHP-AX, The system cuts out when low pressure error shows on the display panel. I spent just £1000 with a company who seemed to replace filters and added a bit of extra piping etc... They never checked the unit outside and never fixed the problem'
    Apologies if i'm sounding daft , so it could be various things that could cause fault. Only external factors i can think would be airflow or circulation based issues or am i missing something? All other factors would be related to the refrige side? Just makes sense to me to get the refrige checked at the same time so i may save chasing my tail if it is say a faulty low pressure switch. Or am i taking the wrong approach
    Jun 2013
    1,743
    What is the low pressure error referring to?
    Refrigerant side or water side.
    It's probably something you should find out from the customer prior to attending the property.
  6. The Following User Says Thank You to oz-plumber For This Useful Post:
  7. #5
    Feb 2016
    102
    I am assuming it's the low pressure on the compressor side. Don't see a mention of a low pressure switch on the water side in the manual. In the trouble shooting guide there is loads of things to check. It mentions various checks on the 'brine' circuit. Have not heard of a 'brine' circuit before, is this just another wording for the heating system
  8. #6
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,601
    We look after an estate in Leeds with about 30 AX air source heat pumps. They are not the most efficient unit but they are pretty reliable refrigeration wise. Its worth checking the connectors within the internal control panel as I have a good few with both high and low pressure errors being down to a bad connection on the plugs on the PCB a squeeze with a pair of pliers does the trick.
  9. The Following User Says Thank You to quality For This Useful Post:
  10. #7
    Howsie's Avatar
    Surrey
    5,208
    Quote Originally Posted by SmokeyJ View Post
    Brine would imply it's a GS heat pump. 1+1=2. Job done.
  11. The Following User Says Thank You to Howsie For This Useful Post:
  12. #8
    Feb 2016
    102
    Quality - Thanks I'll give them a check.
    Howsie - I was wondering but I'm sure its a ashp, thinking troubleshooting guide in manual may be a bit generic. Manual I have is for the dhp-ax ashp.
    Main query was if it is likely to be a refrigerant or a water side issue. Seems that it could be either so I'll go have a look
    Work mate said it may cut out on low pressure when on defrost if it's not getting the temp rise from the heating?
    Going to site tomorrow so will get more of an understanding of what's going on.
  13. #9
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,601
    Make sure the out coil is clean as a whistle
  14. The Following User Says Thank You to quality For This Useful Post:
  15. #10
    Member Worcester's Avatar
    Jun 2011
    971
    Some of the old Danfoss ASHP's were GSHP's with a brine (glycol filled) coil used as an air collector !!! Those are the Danfoss DHP-A and DHP-AX units
    The DHP-AQ units are the usual Monoblocs
    Howsie likes this.
  16. #11
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,601
    No the DHP AX were their first true DX coil/Evaporator ASHP as opposed to the DHP A which was effectively a ground source unit with a glycol fan coil. The DHP AX are also mono block units
    Howsie likes this.
  17. #12
    Jun 2011
    971
    Thanks quality, happy to stand corrected, the manuals I have for the AX units have glycol circuits in them .... left hand not knowing what the right hand was doing ?
  1. Which air source heat pump?
    By willing2learn in forum Renewable Energy
    Last Post: 29-01-2016, 07:38 AM
  2. tried to release pressure from the pressure gauge and now heat won't work
    By catherine 22 in forum Oil and Solid Fuel Forum
    Last Post: 29-01-2013, 11:02 PM
  3. Air source heat pump help
    By Dave Walker in forum Renewable Energy
    Last Post: 21-10-2012, 06:56 PM
  4. MCS & heat pump heat loss calculations
    By Nostrum in forum Renewable Energy
    Last Post: 11-04-2012, 05:02 PM
  5. airsource heat pump
    By northcarr in forum Central Heating Forum
    Last Post: 06-12-2009, 11:20 PM
