Results 1 to 10 of 10
Plumbing & Plumbers Forum - best eco heating syem
Discuss best eco heating syem at UK Plumbers Forums; im trying to buy a house, at present its got a old lpg combi installed, it would cost a bomb to run I imagine, and as im doing it up ...
    884
    Default best eco heating syem
    im trying to buy a house, at present its got a old lpg combi installed, it would cost a bomb to run I imagine, and as im doing it up to sell on after living in it for a few years (2-3 tops) im thinking I can ad a bit of value by installing some kind of eco heating system , heat pump , solar ect, im going to be installing a wood burning stove as it is, but as I work long hours and the mrs is afraid of fire so wont have it on in the house by herself it would rarely be light, but im looking to link this into the system (thermal store I imagine?) what else would you fit? heat pump ? solar ? ground source is not an option due to lack of space as is oil really . or am I better off putting solar thermal and a system boiler? want to keep it at around the 4.5k mark materials only! can it be done?? think it would be a big selling point when I come to sell the house, would you fit ufh ? or stick to rads? ufh would mean lifting all the ground floor up, so id rather have rads . this kind of think is very new to me, im afraid im a combi type of guy . if it cant be done I will be shoving a vokera in to keep cost down!
    lame plumber's Avatar
    Nov 2012
    North Devon by the sea
    15,667
    Default Re: best eco heating syem
    you can drill a hole for a ground source heat pump, so space not a problem if you want to go down that route
    www.jcdheating.co.uk
    884
    what about a heat pump? expensive job?
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,638
    Bore holes for ground source are not an option with that budget but air source is the easiest option
    Chalked's Avatar
    3,933
    I'm on lpg. It's not that bad cost wise at the moment.
    If your trying to make a profit, don't waste your money, stay with lpg
    tamz's Avatar
    Scotland
    13,973
    You won't get much of much on renewables even going for the cheap chinese stuff for a 4.5k budget. I'd buy a sheepskin rug and teach yer wife to not be afraid of fire for a start then go from there
    tamz's Avatar
    Scotland
    13,973
    £1500 and dross for stove, flue and glass hearth and 3 hours of my time start to fire lit.best eco heating syem-imag0747.jpg
    tamz's Avatar
    Scotland
    13,973
    2 windows 3 ft behind this stat are wide open. There is no snow on my roof lol
    Mar 2013
    297
    Quote Originally Posted by CXR100 View Post
    If you're looking at using a heat pump with rads the CoP will suck due to the higher temps needed unless you fill your walls with massive rads to take the lower temps :-)
    Best stick with LPG and put your money into improving the insulation.
    Member Worcester's Avatar
    Jun 2011
    973
    if it cant be done I will be shoving a vokera in to keep cost down;
    You've already made you're mind up
    Shove in an oil boiler and do the minimum you can to make it all look nice.
    oil = cheapest form of heating currently available - it's half the cost of mains gas.
  1. Need Heating Engineer experienced in Wirsbo/Uphonor Underfloor Heating SG12 area
    By Fozzie Bear in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 23-10-2015, 08:15 PM
  2. Replies: 21
    Last Post: 14-12-2014, 04:04 PM
  3. Replies: 6
    Last Post: 08-10-2014, 09:42 PM
  4. Replies: 3
    Last Post: 15-11-2013, 09:26 AM
  5. South Yorkshire -heating engineer to fit heating system inc underfloor and rads
    By harrylime in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 01-07-2012, 12:17 PM
