Results 1 to 12 of 12
Plumbing & Plumbers Forum - Ecodan advice needed
Like Tree6Likes
  • 1 Post By quality
  • 4 Post By LesleyC
  • 1 Post By SimonG
Discuss Ecodan advice needed at UK Plumbers Forums; We have moved into a property with an Ecodan air source heating system (some underfloor heating and some radiators). I have set it to run 24hrs as it is winter. ...
    Feb 2016
    S75
    Default Ecodan advice needed
    We have moved into a property with an Ecodan air source heating system (some underfloor heating and some radiators). I have set it to run 24hrs as it is winter. We also have a gas aga with aims but this is for cooking only. Mostly the house is warm house, but there are areas that are not so warm, such as the downstairs shower room that only has a heated towel rail, and the extension that has under floor heating. I need someone to guide me with this, I also need someone who knows what they are doing to service the system as it is 2 years old. Mitsubishi is too expensive.
    lame plumber's Avatar
    Nov 2012
    North Devon by the sea
    15,664
    Default Re: Ecodan advice needed
    pay peanuts, get monkeys
    www.jcdheating.co.uk
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,598
    Where are you based ?
    Feb 2016
    S75
    S75
    Feb 2016
    S75
    S75
    Member Worcester's Avatar
    Jun 2011
    971
    Servicing on an ecodan is basic, it's all in the user manual.
    Setting up your heating system requires a professional to come and look at it and identify any faults / reconfiguration etc.
    Rule 1 with heat pumps, they aren't boilers, don't switch them on and off, don't turn the heating up and down, program it and leave it to do it's job, it will work most efficiently then. Properly designed they are 'right sized' and use weather compensation / heat curves as standard.
    Our experience is that often the ufh actuators are mis-wired (linked to the wrong stat ) found that 3 times in the last 3 visits to 'other' installers systems.
    Feb 2016
    S75
    Thank you Worcester, so do I need an Ecodan engineer, or would a regular heating engineer be able to service and make any necessary fixes (Mitsubishi said it would need a antifreeze top up).
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,598
    PM me your contact info I am Mitsubishi Ecodan approved installer also not to far from your location
    croppie likes this.
    Jun 2011
    971
    Quote Originally Posted by LesleyC View Post
    Spk to quality, you need someone that knows heat pumps. And I'd always go for an approved installer
  10. The Following User Says Thank You to Worcester For This Useful Post:
    Feb 2016
    S75
    Thank you Worcester
    Feb 2016
    S75
    A big thumbs up to quality for his advice and inspection. Very pleasant and knowledgeable chap, I can now relax and enjoy my heating system :-)
    SimonG, SmokeyJ, quality and 1 others like this.
  13. #12
    SimonG's Avatar
    16,035
    Nice one quality
    quality likes this.
  1. Ecodan query
    By stratplus in forum Renewable Energy
    Last Post: 22-03-2015, 09:43 AM
  2. Advice needed!
    By Niallmat in forum Plumbing Forum
    Last Post: 06-07-2012, 11:16 AM
  3. Ecodan
    By eaton in forum Renewable Energy
    Last Post: 14-11-2011, 09:17 PM
  4. advice needed please
    By modster in forum Plumbing Forum
    Last Post: 17-10-2011, 09:50 PM
  5. Hi all, advice needed
    By rocketmanbkk in forum New Member Introductions
    Last Post: 29-04-2011, 05:44 PM
