Results 1 to 12 of 19
Plumbing & Plumbers Forum - Ground source heat pumps
Discuss Ground source heat pumps at UK Plumbers Forums; I'm having a dispute with my not so better, better half. I'm looking for a good explanation on how this technology works and just how efficient it is. The trouble ...
    Plumbers Arms member secret squirrel's Avatar
    Feb 2009
    Essex
    2,531
    Wink Ground source heat pumps
    The trouble is the results I've got on google are not too informative, the argument is typical "it can't work"
    Of course, I keep saying it does and explain it with my limited knowledge but without facts and figures I'm fighting a losing battle, this is one battle I'd like to win...........Just one, it isn't too much to ask is it?
    So, to all the renewable boffins, PLEASE?
    learningplumin
    Default Re: Ground source heat pumps
    HI, done a lot on refrigeration, but would be surprised if you saved more than £160.00 annual!
    Mar 2009
    142
    It's a fridge in reverse .. you put in 1 Kwh to power the compressor & get 3.5 in return this will reduce as the heated water gets hotter . High installation cost but if it lasts for 5 years you might get yr money back.
    Downside is they used to only get about 45 deg water I think now is better. "New" technology is being developed using CO2 as the refrigerant at much higher internal pressures but also higher performance.
    TG
    oldplumber
    it will only work if your home is so well insulated that it looses very little heast otherwise in an average property you will be paying out more in electricity than you really gain in return. My other bugbear is that the equipment and install costs are to high at present to really make a cashback return in 10 yrs or more, better off fitting a really efficient boiler with indoor and outside modulating stats to run the boiler at its most efficient means
    Feb 2009
    Essex
    2,531
    old Plumber:
    I'm not really into renewables for the reason that you have to spend a considerable amount of money in the first place and takes so long to get the money back. So, regretably (I'd like to be green) I have to agree.
    Tgor:
    Hello, can you give me a bit more, how deep down do you dig length of pipe, how is the heat drawn from the ground. If, you need a bit more info, for arguments sake lets go for a 3 bed semi detached house, good insulation, lounge, kitchen.......
    oldplumber
    contact the manufacturers like worcester, grant etc, they are so kean to sell a rep will get back to you asap and probably visit if you are really serious.
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,598
    Ground source heat pumps are the bees knees but they are not to gentle on the pocket initialy or are they at retro fitting into your average house but air source is another more affordable option
    stevetheplumber's Avatar
    east london
    10,613
    personally im of the opinion that if your using renewables because it will ease your green concious fine if your thinking it will save you money think again
  9. The Following User Says Thank You to stevetheplumber For This Useful Post:
    unguided1's Avatar
    Oct 2008
    oxfordshire
    1,981
    although I have no personal experiance of installing Ground Source I have looked into them.
    the biggest problem with them is that if they are not installed or sized correctly, all they will do is freeze the ground they are also installed with big back up immersions to make up any shortfalls.
    I have heard of cases on other forums where the ground loops have frozen up after 18 months of use and they no longer efficiently,
    The other big draw back of course is the initial cost of the unit plus the installation
    if its not dangerous Im not doing it
    im not here to be helpfull! How am I doing?
    Dec 2009
    Kidderminster
    251
    Ive just started working on ground source and i think its brilliant but like unguided says if the spec isn't right you can have problems such as the ground not recovering thermally during the summer but this could be 2 years down the line as it would gradually get worse year after year! As far as i can see the actual units are pretty bombproof, every one i get called to fix is installer error ie. not enough antifreeze in loop, system piped incorrectly, not enough lagging, air in system is major! Trying to educate customers to use system a little differently to their old boiler.
    Mar 2009
    142
    I have not a clue as to the installation methods for ground source HP .. I don't really think anyone does fully .. its a bit "experimental" .. I would rather put my money on the development of air-water heat pumps using CO2 as the refrigerant .. a much higher COP and works at low outside temps. Lots of trials done in Japan, sounds more promising.
  13. #12
    unguided1's Avatar
    Oct 2008
    oxfordshire
    1,981
    I went to look at a ground source heat pump earlier this week, apparantly the equipment was supplied by a company called Ice Energy, but I would also like to add that they did NOT do the installation.
    The supply pipe from the ground loop was -1 degrees C and the return pipe to the ground loop was -5 degrees C.
    The customer is complaining that it is costing an absolute fortune to run.
  1. Ground source heat Pumps
    By darren bastin in forum Central Heating Forum
    Last Post: 08-11-2012, 09:26 PM
  2. Ground Source Heat Pump
    By Bartdude in forum Renewable Energy
    Last Post: 19-10-2011, 09:10 AM
  3. Air Source Heat Pumps
    By jddevel in forum Renewable Energy
    Last Post: 16-03-2011, 08:54 AM
  4. Air Source Heat Pumps
    By mark6266 in forum Plumbing Forum
    Last Post: 12-08-2010, 07:27 AM
  5. Ground/air sourse heat pumps
    By fuzzy in forum Renewable Energy
    Last Post: 09-07-2010, 04:20 PM
  6. Ground source heat pumps
    By secret squirrel in forum Plumbing Forum
    Last Post: 01-03-2010, 07:00 PM
  7. air source heat pumps
    By unguided1 in forum Plumbing Forum
    Last Post: 08-10-2008, 06:06 PM
fridge diy ground source heat pump
ground loop length for 3 bed semi
