Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Plumbing & Plumbers Forum - Ground source heat pumps
Discuss Ground source heat pumps at UK Plumbers Forums; The main difference with renewables is you really do have to do your maths properly with regards to heat loss as the amount of energy harnessed is often fixed by ...
  1. #13
    Sep 2009
    66
    Default Re: Ground source heat pumps
    The main difference with renewables is you really do have to do your maths properly with regards to heat loss as the amount of energy harnessed is often fixed by how much solar radiation a patch of ground can absorb, which direction your roof is facing etc... You have to remember a large part of the domestic heating industry only install combi boilers use a mears calculator to size and rarely use pipe above 22mm, if you use the same logic with renewables you will not get great results.
  2. #14
    oldplumber
    i suppose gakmonkey's comments should have been followed by the government as most windfarms only seem to profitable due to their funding, most of the turbines i have passed are always at a standstill!!!!!!!!!!
  3. #15
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,748
    Approximately you need a plot of land 2-2.5x the area of your house. For a 10Kw GSHP you would need 3 trenches 50m long 5m apart and 2.5m from any boundary. Vertical slinkys need to be installed in a 2m deep trench, horizontal slinkys in a 1.2m deep trench. Vertical bore holes are another way, but a lot more expensive. This info is approximate as it does depend on ground conditions. Insulate, insulate, insulate. is the way forward not just for renewables.
  4. #16
    Mar 2016
    Heat pumps can be a nightmare if not setup correctly the ground water has to be
    The right flow and not too cold I've been to some installations and they didn't have
    A constant flow so the unit cut out on evap flow and it can use massive amounts of
    electricity if just put in and switched on .
  5. #17
    Member Spanish's Avatar
    73
    personally im of the opinion that if your using renewables because it will ease your green concious fine if your thinking it will save you money think again
    installed pv on roof 6 years ago, paid itself back and this year my energy costs total will be in the region of £750 but the pv will pay me £1500 so it does work,
    Have just had a few quotes for GSHP and will be going ahead, it is a refurb and the insulation will be over and above current recommendations so the GSHP will pay for itself (if works to 75% of expectation) within the 7 years
    My dogs speak more sense than most people I meet
  6. #18
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,629
    This site is mainly hung on natural gas, oil or lpg. there are not many of us who are fitting renewables which is what most gas engineer fear
    Worcester likes this.
  7. #19
    Mar 2013
    295
    Quote Originally Posted by quality View Post
    Over the years I've seen some renewable installations which worked pretty well and many others which were completely pants. Some retrofit jobs should never have been taken off the drawing board and end up costing a sight more to run and install than equivalent oil/lpg. I've also found not all major contractors/consultants are clued up on them either so going to the big boys doesn't always equate to a good installation!
  1. Ground source heat Pumps
    By darren bastin in forum Central Heating Forum
    Last Post: 08-11-2012, 09:26 PM
  2. Ground Source Heat Pump
    By Bartdude in forum Renewable Energy
    Last Post: 19-10-2011, 09:10 AM
  3. Air Source Heat Pumps
    By jddevel in forum Renewable Energy
    Last Post: 16-03-2011, 08:54 AM
  4. Air Source Heat Pumps
    By mark6266 in forum Plumbing Forum
    Last Post: 12-08-2010, 07:27 AM
  5. Ground/air sourse heat pumps
    By fuzzy in forum Renewable Energy
    Last Post: 09-07-2010, 04:20 PM
  6. Ground source heat pumps
    By secret squirrel in forum Plumbing Forum
    Last Post: 01-03-2010, 07:00 PM
  7. air source heat pumps
    By unguided1 in forum Plumbing Forum
    Last Post: 08-10-2008, 06:06 PM
fridge diy ground source heat pump
ground loop length for 3 bed semi
