Results 1 to 12 of 16
Plumbing & Plumbers Forum - Green deal / Eco funding
Like Tree7Likes
Discuss Green deal / Eco funding at UK Plumbers Forums; Hi all Have any of you took the plunge on this. We are pas 2030 now but now not sure it's for us now due to all the bad press ...
    Apr 2013
    120
    Default Green deal / Eco funding
    Hi all
    Have any of you took the plunge on this. We are pas 2030 now but now not sure it's for us now due to all the bad press on the providers being bad payers.
    Has anyone got any personal exsperence with this.
    Cheers
    Banned
    Jun 2013
    351
    Default Re: Green deal / Eco funding
    I do know some are asking for 60 days payment terms, but if the 60 turns to 120 I don't know.
    Jul 2013
    I waited 9 weeks for plumb centre to sort out my eco application......went live for one day and gets a email saying no more assessments!!! **** take
    Ermintrude likes this.
    Mar 2014
    Nearly a year later, is this still the case?
    Member Worcester's Avatar
    Jun 2011
    973
    Yep, same old, same old. Process is a nightmare, no eco funding available to support green deal applications and GDP's taking ages to pay installers...
    Mar 2014
    So if I was conscious about my environmental impact, what can I do? Without being financially screwed?
    Jun 2011
    973
    Look for things that are RHI backed..
    Consider the Green Deal as a Process not a solution, also consider GDA's as Green Deal Assessors, NOT Advisers as they are SUPPOSED to be..
    #1 Insulate
    #2 Insulate
    #3 Insulate
    What is the current fabric of your house?
    Look at Loft (250mm at the LEAST), Cavity Wall, Exterior Wall (EWI) and Interior Wall (IWI) Insulation plus better windows and doors
    Draught proof every where
    If you go for a Green Deal Plan, you DO NOT have to take the finance (so you can fund it yourself) to get any ECO contribution that you may qualify for e.g for IWI or EWI
    I expect that some ECO money will start to become available late April / May time.
    Then look at how you heat the house - if you are on mains gas, the make sure you have a modern efficient reliable condensing gas boiler.
    Also install at a timer and least one room stat and TRV's on all the remaining radiators, better still go for the honeywell evo system that lets you effectively zone the house into up to 8 (12) zones with different temperatures and different times. If you've got a hot water cylinder and immersion, consider adding PV and using an ImmerSUN unit to heat the hot water via the immersion for "free". The FiT will more than compensate you for the capital installation cost.
    If not on mains gas grid, then if you can get your heat loss below 50w/m2 consider an Air Source Heat Pump, and new larger radiators to get the flow temperature down to 45° . - The RHI will once again compensate you for the capital installation costs.
    If still struggling with the heat loss the fit a quality biomass boiler, or maybe even a Ground Source Heat Pump, if you don't have land, you can go for a vertical collector (aka borehole), once again the RHI will compensate you for the capital installation costs.
    IF you are of good financial standing then finance it initally yourself / take out a commercial loan - the RHI repayments are designed to cover that scenario.
    IF NOT of such good standing then a Green Deal Finance plan MAY be available to cover the capital costs...
    Latest from Barking ... Domestic RHI (DRHI) will be live BEFORE EASTER.
    FACT: The DRHI went through the first pass of the House Commons a few weeks ago, and cleared the House of Lords yesterday (26th March), is back to the House of Commons on the 2nd April.
    Supposition:
    so pre-Easter Launch on target...
    Look here:
    Charging the Earth - Solar!
    Charging the Earth - Solar!: Heatloss+Energy
    Tony Robins likes this.
    Mar 2014
    Thanks Worchestre, You really know your stuff. It was very informative thank you.
    I was going to say, I thought the DRHI wasn't approved for domestic buildings yet. (but you had already covered that at the end).
    So if there was one change that could be made to an existing house to make it more eco-friendly, what would it be?
    Killy Bing's Avatar
    Nov 2012
    Maidstone, kent
    4,251
    Quote Originally Posted by Tony Robins View Post
    eco friendly or money efficient?
    Or a mix?
    insulate the place upto the hilt before you do anything.
    Reducing your energy losses reduces your bills.
    With a well insulated house a dry wood stove can do a fair chunk of the space heating for say the kitchen or main living area.
    you can then time the boiler to run for bedrooms to be heated before you go to bed.
    there is always rainwater harvesting which can be then plumbed in to run your toilets.
    worcester will explain more on the solar thermal +pv side, heat pumps and biomass.
    but remember most of these are useless without an energy efficient home.
    wetdrip, Worcester and Tony Robins like this.
    hey ho, here the hobbit go
    visit us at
    www.prestigeplumbers.co.uk/
    Jun 2011
    973
    #1) By a long way the single most important thing to do is Insulate ...
    Inherently eco friendly, as even if you carry on using carbon fuels then you will be using less of them.
    #2) Central heating controls
    Get greater control of your times and temperatures, that way you can easily cut your consumption - see also Killy Bing's comments
    #2) Solar PV with Immersun (if have a cylinder)
    Has pretty much a guaranteed ROI, and if installed properly will need little or no maintenance for 20 years, and enables you to use your own 'green' energy
    #3) As my earlier comment how you heat the home, this depends upon your current heating source.
    Sep 2008
    penicuik
    350
    Been looking into the outside wall insulation for my own house....I have a no-fines house. Would it be possible , where would I go to see about it.
    Am now with a green deal firm, but everything is so vague grr
    (Easier to stick to plumbing n heating methinks )
    Ermintrude's Avatar
    North East
    13,337
    I was at a job today. Private but 100 or so no fines were covered in scaff , mite were doing work but pulled off on jan as no money left. Half done , not started, just scaffolding. Estate looks a mess. Get it done early in financial year!
    my posts may appear blunt or sarcastic........ that's because they are!
  1. hello
    By uug197h in forum New Member Introductions
    Last Post: 15-10-2015, 08:19 AM
  2. The Green Deal
    By JAH HEATING in forum Renewable Energy
    Last Post: 29-10-2013, 09:53 PM
  3. Green deal
    By Alex4rt in forum Plumbing Forum
    Last Post: 12-06-2013, 02:32 PM
  4. green deal
    By alexmurchison in forum Oil and Solid Fuel Forum
    Last Post: 04-03-2013, 10:22 PM
  5. green deal
    By roguetrader in forum Plumbing Forum
    Last Post: 20-02-2013, 01:33 PM
  6. Green Deal
    By Foodface in forum Plumbing Forum
    Last Post: 05-02-2013, 09:04 AM
  7. Green Deal
    By Rob Sale in forum Gas Safe Register Forum - Public Forum
    Last Post: 21-09-2012, 10:09 AM
7 day payment eco funding
greendealeco
