Results 1 to 12 of 13
Plumbing & Plumbers Forum - Daikin Altherma HT
Like Tree2Likes
Daikin Altherma HT
Discuss Daikin Altherma HT at UK Plumbers Forums; Anyone fitting these units yet? I've just recently went and completed my F-Gas C&G 2079-11 and I'm looking at installing them. Quite interesting reading about their 80 o C output. ...
    CES
    CES is offline
    CES's Avatar
    Sep 2010
    Livingston
    2,497
    Default Daikin Altherma HT
    I've just recently went and completed my F-Gas C&G 2079-11 and I'm looking at installing them. Quite interesting reading about their 80oC output.
    Looking at doing the Daikin training in Jan/Feb. Anyone any thoughts on these?
    Mr ODT likes this.
    If you cant fix it with a hammer, you've got an electrical problem..
    Cha togar m' fhearg gun dìoladh
    GSR? want gas safety or boiler repair advice? we will check out that your genuine via the gas safe website,so please don't be offended when we ask for your details diyers, potchers, odd job people and have a go heroes need not apply
    Aug 2010
    55
    Default Re: Daikin Altherma HT
    We've fitted about 20 HT units and had no problems. As long as they are sized correctly you won't have a problem. ? They get up to emperature quickly and the hot water cylinder that comes with it heats up quickly too. If you have the cylinder sitting on top of the indoor unit you do need about 2.3M headroom but you can put them side by side.
    There is a small amount of noise from the indoor unit as it has a small compressor in it that takes the temperature up to 80 deg. so be careful on where you site it.
    I would thoroughly reccomend the unit. Good luck.
  3. The Following User Says Thank You to mooreofdevizes For This Useful Post:
    CES
    Feb 2013
    Hi CES,
    this is my first post and I am too quite interested in The Daikin Altherma and Mitsubishi Eco Dan from what the manufacturers say about them...but as we know what they say and how they perform could be completely different being fairly new technology..
    I install splits for a small family plumbing business who I'm going to try and get me on the trainning courses..Appreciate some feedback on the training courses if u attend.?
    gasmanrob's Avatar
    Medway
    3,238
    First time I see one I thought it was a fridge!
    The manual on gem was big enough to scare me so I am looking at going on the makers course at some point
    Mar 2013
    37
    Stay away from the mitsubishi's, I work for local housing associations and we have nothing but problems with them and there far too complicated for what's needed, daikin on the other hand are a very good unit and can thoroughly recommend them.
    Apr 2009
    N. Devon
    652
    Just double check that they are MCS, as a lot of the HT units Iv seen haven't been which voids it of any grants/incentives which are quite handy!
    May 2013
    Perth
    I have fitted the best of china rubbish and the daikin altherma ht/lt units and the advise is you get what you pay for. The daikin units are great but make sure you do heat loss calculations are correct and go on there training course because it is alot to take in from the manual.
    Oct 2007
    968
    Best course to go on is Panasonic Aquarea because its free and you get fed & watered for nothing foods great. The course was pretty good as well.
    Beer is the reason I get up every afternoon.
    Dec 2013
    Default
    Hi Moorofdevizes, I am looking to get a Daikin HT maybe installed in our 400 yr old listed bldg house in Cornwall - 3 beds, 1 bathroom only 2 of us there most of the time now.. It is quite mild but we can only have loft insulation and draft proofing on windows as insulation methods due to listing. We have wood stoves and an oil Aga at the moment. My question is can a Daikin HT cope with such a bldg or will our electricity build be huge?
    Any help gratefully received
    Member Worcester's Avatar
    Jun 2011
    973
    Default
    Quote Originally Posted by Envirheat View Post
    Air source heat pumps only really work on well insulated homes, both the CTC and Daikin as well as a few others offer high output units, however in most cases the CoP drops though the floor (CTC being the probable exception)
    The only way that your question can be answered is a proper heat load survey, measuring room sizes and calculating insulation values - once that's done you'll have your answer, and not until - else wise they are just guessing, and you end up with yet another of those under-performing systems..
    Heat pumps work when PROPERLY DESIGNED. You need full room by room heat loss calcs to be able to make the decision.
    Whichever renewable heat source that you choose it's a requirement of the MCS scheme and the RHI to have full room by room heat loss calcs done to BS EN 12831 anyway. So that should be your first step. (You'll also need an EPC and GDAR, those are wonderful works of fiction though )
    If you are on oil, and aren't well insulated your best solution would usually be a Biomass boiler.
    Nostrum likes this.
    strumbeat
    Cool Re: Daikin Altherma HT
    Hi Guys,
    Anyone able to give advice on using 5 x HT's in parrallel with a plate heat exchanger to heat up two tanks for a gym with 22 showers >?
    Collector sizing / what would you use , just a large pipe ?
    would the on board pumps cope with the 20kPA drop through the Heat Ex.
    Do you treat the closed loop " primary " circuit ?
    Does anyone have a recommended schematic or tank manufacturer
  13. #12
    Jun 2011
    973
    Call Daikin technical they'll do it all for you
    Though these are pretty fundamental questions - worrying if you are asking these - if you want more detail and more answers please register
    You need to know usage, recovery times etc etc. Pipes sizing calcs are standard bearing in mind the Delta T ..
    We'd be happy to quote
  1. Daikin Altherma
    By clivetheplumber in forum Central Heating Forum
    Last Post: 27-09-2012, 07:04 PM
  2. "Daikin" Air Pump low temperature Central Heating System-Switch Off ??
    By Border Collie in forum Central Heating Forum
    Last Post: 14-05-2012, 09:59 PM
  3. Daikin air to water heat pumps.
    By jimplumb in forum Renewable Energy
    Last Post: 13-10-2010, 10:11 PM
daikin altherma problems
daikin altherma ht problemsnoisy altherma htctc or daikinaltherma not working
