Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 25
Plumbing & Plumbers Forum - Which air source heat pump?
Like Tree3Likes
Discuss Which air source heat pump? at UK Plumbers Forums; Husky Air Source are one of the best new comers and very competitively priced. We typically can supply and install one for around £1500 less than Eco dans etc....
  1. #13
    May 2012
    Default Re: Which air source heat pump?
  2. #14
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,598
    Danfoss AQ is a good performing unit but not cheap
  3. #15
    eaton's Avatar
    Cambridgeshire
    279
    I'm the same can supply and fit for nearly a quarter less than the Ecodan quotes out there
  4. #16
    Dec 2009
    871
    Quote Originally Posted by ecowarm View Post
    Google Earth save products, give them a ring or email, very friendly and helpful people. Ask about the Ecocent hot water cylinder, and their knowledge of heat pumps is second to none
    All products I have seen from them is direct from China.
    Daiken are a trusted brand for both major projects and small domestic systems, maybe a bit dearer today but you save that into the future with reliability and a manufacturer who does have after sales support.
  5. #17
    Dec 2009
    871
    Markfxy, the ecocent can take air from outside, or warm moist air from a shower room or kitchen and then return cool fresh dry air somewhere you may need it
    The kitchen or shower room are not always full of warm moist air that we need to get rid of so they will be pulling heat from the kitchen / shower room which has to be replaced, so no savings there.
    If they are pulling the air from outside the house (standard heat pump method) the C.O.P. will drop big time in winter, honestly if you are anywhere in the north of England, Ireland or in Scotland fit a standard immersion at least they are honest.
  6. #18
    22
    Have you seen the Panasonic range of heat pumps? They bought out Sanyos CO2 and also had there own long standing range. They have heat pumps that are high temp 65 flow and ones that guarantee output to -15 degrees. ie 12kW at 7 degrees and 12kW at -15 outside air temp with no back up electric heater, yes the COP drops but overall they have good COP's. They seem very well priced. I just did there training. They are also inverter driven (variable output) with 0.5amp start current.
    I also import and fit wood pellet boilers, take a look at Extraflame's low cost domestic range. MCZ products is also worth looking at. They both do combined stove boilers to from 12kW to 24kW and a range of pellet boilers from 14 to 31kW that are MCS approved and well priced.
  7. #19
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,748
    Quote Originally Posted by peteheat View Post
    Give them a ring Pete, very helpful people. They will put your doubts to rest.
  8. #20
    Dec 2009
    871
    I know the products because I can buy direct from the manufacturers in both Italy and China.
    I am looking at a small heat pump that is mounted outside, easy to fit works with standard cylinders and coils COP of 3.5 when outside temperatures are above 3c drops to 3 when outside temps hit oc.
    Should be interesting to see the engineers final report, it better be a long report considering what it's costing me :-)
  9. #21
    May 2012
    Ice stick, octopus heatpump system, no drilling into the ground, only a compressor, swedish design, also hot water cylinder with heatpump , ho****er 24/7, easy to fit; i've fitted the ice stick to new and old heating systems, and the unit is gauged,so i can tell how its performing, new build insulated house 2000 square feet 550 to 600 euros a year to heat; hotfoot .ie is the company ;
  10. #22
    Nov 2015
    Quote Originally Posted by willing2learn View Post
    Hi Mark, do you have any experience with the ecocent cylinders then? The plan was to have the vents over the showers and near the log burner, and maybe on in the utility room.
    willing2learn - did you make a decision? - we are in similar situation except that I am electrically qualified but not a plumber
  11. #23
    Member Worcester's Avatar
    Jun 2011
    971
    ecocent / Giona / et al take heat from the house, i.e. it will take it from the radiators, underfloor heating etc.
    So in practice you heat the house and then take that heat to heat the water. Some of the units can take air direct from outside.
    It's an air source heat pump by any name. so depending upon how you are planning to heat the house depends upon whether it will be efficient or not.
    From another post:
    The man at Giona strongly advised against using an internal source for the inlet because it would be taking heat out of the house which has to be replaced by drawing heat in from the outside. Logically it makes no sense to me to be pumping warmth out of the house only to draw cold air back in. He stated that the inlet and outlet would both be outside.
    ASHP's based on our experience
    Tier One: Panasonic , Daikin
    Tier Two, Samsung, Mistubishi
    Nibe are unnecessarily complex, Dimplex units cannot comment on, Mistubishi complex to set up CORRECTLY..., Danfoss no direct UK support, so you're on ya own..
    Best Installer Support #1 Panasonic, #2 Samsung.
  12. #24
    40
    Can't pass comment on other manufacturers, all I've fit is Mitsubishi and find them to be really good. Flow rate through heat pump is very important. Avoid microbore, depending on the distance from heat pump to cylinder and size of heat pump but to be safe use 28mm between heat pump and cylinder. I actually find the technical very good (certain lads anyway) pre sales speak to Louis Sousa
  1. Moving an air source heat pump
    By dean82 in forum Central Heating Forum
    Last Post: 04-04-2013, 06:29 PM
  2. moving an air source heat pump
    By dean82 in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 31-03-2013, 07:29 PM
  3. air source heat pump installation
    By harry22 in forum Plumbing Forum
    Last Post: 04-11-2012, 10:46 AM
  4. Air Source Heat Pump question - please help!
    By thebeefchief in forum Central Heating Forum
    Last Post: 25-10-2012, 01:44 PM
  5. Air source heat pump help
    By Dave Walker in forum Renewable Energy
    Last Post: 21-10-2012, 06:56 PM
  6. Air Source Heat Pump
    By Leoki in forum Renewable Energy
    Last Post: 20-02-2012, 09:01 AM
  7. Ground Source Heat Pump
    By Bartdude in forum Renewable Energy
    Last Post: 19-10-2011, 09:10 AM
  8. air source heat pump
    By erj in forum Central Heating Forum
    Last Post: 01-06-2011, 07:50 PM
  9. Air source Heat pump - a few questions
    By willow2 in forum Central Heating Forum
    Last Post: 16-01-2011, 11:41 AM
  10. Hello
    By Varley in forum New Member Introductions
    Last Post: 01-07-2007, 02:14 PM
mitsubishi air source heat pump reviews
hitachi air source heat pump reviews
earth save products reviews
samsung air source heat pump reviews
samsung heat pump reviews
