Results 1 to 4 of 4
Plumbing & Plumbers Forum - Bio-Mass boiler to replace Trianco solid fuel Boiler
Discuss Bio-Mass boiler to replace Trianco solid fuel Boiler in the Renewable Energy at Plumbers Forums; Hi Everyone ,been lurking on the site for a while and thought I would ask advice on a Install i am currently in the process of Planning. Background as follows ...-
25-04-2012 #1New to Plumbing Forum
- Dec 2010
16 century farmhouse situated in yorkshire currently running a Trianco solid fuel boiler ,radiators are approx 35 years old and all pipework is in copper burried in concrete on the ground floor ! and normal practice on the first floor
Pumped c/h circuit and gravity hot water .
looking to replace the boiler with a biomass boiler ,unvented cylinder (solar ready) and upgrade all controls .
the boiler originally looked at was the baxi Bioflow but on furthur research an alternative Winhager Variowin boiler is looking to be the favorite , the boiler will be out of sight so the furnace window feature is not required or heat to the room from the furnace.
My background is I am a self employed plumber/heating engineer gas safe registered with lots of experiance of mainly combi installations and a few unvented systems ,I have attended and completed the Woody Bio-mass course at Stevensons collage in coalville .
The customers are my parents and the job will of course be free (labour)
My main worry/concern is the output of the Bio-mass boiler ! will it be sufficent to cope with the heating load and h/w requirements ? I dont want to get this wrong as there will be the best part of £10k being spent !
Any comments or advise would be greatfully recieved
Thanks Dom
25-04-2012 #2UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,737
- 297
- Thanked 374 Times in 357 Posts
Re: Bio-Mass boiler to replace Trianco solid fuel Boiler
Welcome to the forum Dom.
What size do you intend to install?
What is the heat requirement of the property?
Are you to install a buffer/ accumulator vessel?
26-04-2012 #3Plumbers Arms member
- Dec 2009
- 865
- 11
- Thanked 80 Times in 76 Posts
Hi Dom,
What fuel do intend using wood pellet or biomass multi fuel for example logs, black oats etc?
I would recommend a buffer tank as a lot of the modulating boilers can take a long time to respond to heat demand, the buffer irons out the peaks and troughs.
Ecowarm has asked some very important questions the answers would help giving any guidance.
18-06-2012 #4New to Plumbing Forum
- Apr 2011
- 22
- Thanked 4 Times in 4 Posts
I know this post is old. You need deep pockets for a Winhager, all the accessories bump up the price. Did you look at the Grant Spira, Extraflame, MCZ or Woodpecker pellet boilers? The Extraflame, MCZ and Grant don't neeed buffer tanks which can simplify things, although a thermal store is always a good option to consider. I have fitted several of the Extaflame pellet boilers without buffer tanks, they never overheat if done correctly. The wood pecker pellet just need a buffer for back end protection, stop condensation in the heat exchanger, but Woodpecker won't comission without a buffer tank. I am factory trained on the others, so I commission them myself, but always use an anti condense valve.
trianco international muilti fuel stove boiler model
By big lammy in forum Plumbing ForumReplies: 0Last Post: 08-04-2012, 09:26 PM -
trianco solid fuel boiler leak
By joiner wayne in forum Central Heating ForumReplies: 10Last Post: 29-08-2011, 08:08 PM -
Blocked Flue Vents Solid Fuel Boiler (Trianco TRG45)
By dom_trig in forum Central Heating ForumReplies: 0Last Post: 23-08-2011, 11:50 AM -
pump locations for solid fuel back boiler & oil boiler
By mgm2009 in forum Central Heating ForumReplies: 5Last Post: 23-07-2011, 02:39 PM -
Trianco TRG 45 Eurostar Solid Fuel.
By Jazz Head in forum Central Heating ForumReplies: 15Last Post: 14-11-2010, 11:30 AM
stanley tool bag
3 Minutes Ago in Plumbing Tools
