Results 1 to 15 of 19
Plumbing & Plumbers Forum - Retrofit wood-fired hot water into new, oil-fired CH and HW system?
Discuss Retrofit wood-fired hot water into new, oil-fired CH and HW system? in the Renewable Energy at Plumbers Forums; Hi all, I'm feeling rather sheepish as I should have done my homework weeks ago, as you shall see, but I am where I am...! We've recently bought a new ...
    NorfolkBumpkin
    Default Retrofit wood-fired hot water into new, oil-fired CH and HW system?
    Hi all,
    We've recently bought a new house and spent the past few months renovating it, which has included a new Charnwood Cove 2 wood burner and new oil boiler, hot water tank and hot water/CH system (with expansion cylinders rather than a cold water tank in the loft). The plumber we used (who we have no problems with and have used many times before) told me that fitting a woodburner-backboiler into the system would add substantial extra cost and so, disappointingly, we decided against.
    However, I've been thinking that I should have got a second opinion and that is what I am doing now. I'd be grateful if anyone can give me an idea of the feasibility and (very) approximate cost of installing a backboiler onto the Charnwood (you can get a flueboiler to fit our stove which I guess is the sort of thing we'd be looking at) and using this heat to complement the indirect hot water system which is currently heated by the oil boiler (and immersion).
    Any comments gratefully received - please bear in mind that I'm not a plumber so my technical knowledge is limited.
    Thanks,
    Alex
    7,225
    Default Re: Retrofit wood-fired hot water into new, oil-fired CH and HW system?
    Is it an unvented hot water cylinder you have? reading your post it sounds like it.
  3. If You Burn It, It Can Kill You.
  4. The Following User Says Thank You to SimonG For This Useful Post:
  5. #3
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    4,668
    Default
    I agree sounds like unvented
    You can't have an uncontrolled heat source incorporated with unvented cylinders
    Only way you can do it and have mains pressure water is by a thermal store
  6. The Following User Says Thank You to Gray0689 For This Useful Post:
  7. #4
    tamz's Avatar
    Scotland
    9,363
    As everything is unvented it is now a bit of a problem. Solid fuel needs to be connected to vented systems for obvious reasons.
    There are a couple of ways to do it but none are particularly cheap or easy to do now.
  8. The Following User Says Thank You to tamz For This Useful Post:
  9. #5
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,738
    It sound like you have left it too late now Mr Bumpkin, it would be a bigger and more expensive job and defo not DIY
  10. The Following User Says Thank You to ecowarm For This Useful Post:
  11. #6
    quality's Avatar
    Sep 2009
    South Yorkshire
    2,436
    You can have an unvented cylinder heated by your wood burner but you would need an open vented heating system as ecowarm has suggested it will not be cheap to do it Properly
  12. The Following User Says Thank You to quality For This Useful Post:
  13. #7
    7,225
    That'll be the H2 panel then? I noticed on their website they have a version for unvented.
  14. The Following User Says Thank You to SimonG For This Useful Post:
  15. #8
    NorfolkBumpkin
    Many thanks for all of your comments - I may have just to leave it then and carry on forking out on oil! Thanks for your help.
  16. #9
    13
    Hi
    Had an oil fired unvented system feeding a vented dual coil hot water cylinder & sealed radiator system.
    Fitted a Charnwood insert solid fuel boiler feeding it via the spare cylinder coil, tee'd from feed before coil into pump and into existing unvented radiator run (unventing it). Check valves after each pump & standard PSV's in place.
    Happy with performance ran both to max no issues.
  17. #10
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    4,668
    Default
    Quote Originally Posted by Solid Fuel View Post
    Hi
    This don't make sense to me???
  18. #11
    7,225
    Quote Originally Posted by Gray0689 View Post
    Even less to me as he has posted seperate topic on backflow. So it's not running 'no issues'.
  19. The Following User Says Thank You to SimonG For This Useful Post:
  20. #12
    quality's Avatar
    Sep 2009
    South Yorkshire
    2,436
    Quote Originally Posted by SimonG View Post
    Yeh H2 panel it is , I have done a good few of various set ups and had very good results
  21. The Following 2 Users Say Thank You to quality For This Useful Post:
    SimonG (16-11-2011)
  22. #13
    7,225
    Quote Originally Posted by quality View Post
    Still haven't had chance to use one, yet. Customers tend to think great idea, tie in the heating and the stove, until they see how much it will be!
  23. The Following User Says Thank You to SimonG For This Useful Post:
  24. #14
    quality's Avatar
    Sep 2009
    South Yorkshire
    2,436
    Yes this is the down side and it's not just the extra cost of the panels (which ain't ) it's extra work (which can be quite a lot) that boosts the price
  25. The Following User Says Thank You to quality For This Useful Post:
  26. #15
    13
    The Domestic HW is using an vented dual coil hot water tank.
    The original heating system was oil fired un-vented feeding into one of the coils.
    A solid fuel system was fitted using the spare coil on its primary circuit, the oil fired system was turned into a vented system and a both then fed via pumps and check valves into the now vented radiator circuit
  27. The Following User Says Thank You to Solid Fuel For This Useful Post:
  1. advice on zoning a new oil-fired system
    By markproperjob in forum Central Heating Forum
    Last Post: 07-06-2011, 08:39 PM
  2. Wood burner with back boiler and Oil fired central heating
    By Daviddonk in forum Plumbing Forum
    Last Post: 01-02-2011, 07:58 PM
  3. Replies: 11
    Last Post: 31-12-2010, 06:06 PM
  4. No hot water - Oil fired boiler
    By HPPH in forum Plumbing Forum
    Last Post: 09-08-2010, 10:05 AM
  5. wood fired boiler hookup
    By josephus in forum Plumbing Forum
    Last Post: 04-10-2008, 11:24 PM
can i tee oil and solid fuel into one coil
wood fire hot water retrofit
adding a log burner to oil fired ch
fluebioler hotwater
best plumber to fit wood fire hot water system
