Results 1 to 8 of 8
Plumbing & Plumbers Forum - Skylo Unifill 4 in 1 brass shank float operated valve
Like Tree7Likes
  • 2 Post By Mike Jackson
  • 1 Post By gas man
  • 2 Post By Ray Stafford
Discuss Skylo Unifill 4 in 1 brass shank float operated valve at UK Plumbers Forums; Picked up a couple of these the other week as I had a faulty valve to change and due to the boxing in I couldn't tell whether it was a ...
    Mike Jackson's Avatar
    Hastings
    5,495
    Default Skylo Unifill 4 in 1 brass shank float operated valve
    Picked up a couple of these the other week as I had a faulty valve to change and due to the boxing in I couldn't tell whether it was a 10mm or 1/2" thread on the valve. The concept is great, one valve that does both bottom and side entry and two sizes of thread. The valve is also height adjustable which makes it even more flexible. I like the fact that the float is set within it's own little chamber that means it can't jam up against the side of the cistern or the flush valve.
    This has now taken over from the fluidmaster as my valve as choice, especially given the versatility and the price being about 2/3 the price of a brass shanked fluidmaster.
    The only drawback I've come across so far is the shank is slightly shorter than the valves I've replaced but on one there was enough play and the other was connected with a flexi (spit).
    gassafe and TomLane like this.
    SimonG's Avatar
    16,035
    Default Re: Skylo Unifill 4 in 1 brass shank float operated valve
    Where are you buying them from Mike?
    May 2010
    3,451
    A nice glowing review! I will pick one up when I see one... Shame the shank is not the standard length tho, that could cause an issue on the rigid copper installations!!
    We cannot help non gsr's with technical gas or boiler questions. If we do Croppie gets upset and gives us chinese burns......
    May 2010
    5,118
    Spotted these back in Septembers HVP ...how much did they cost you Mike pm me if you dont want it shown in an open forum..I think Ray was looking into these a while back ..regards Turnpin
    Apr 2012
    Farnham, Surrey
    344
    I have fitted loads of the standard Viva Skylo BE and SE valves and have not had any problems with either, except when the pressure is v. good, can cause water hammer, even with the filter fitted.
    I have noticed that the plastic shank is a standard length, but the brass one is always shorter. They have a different filter so maybe this is why?
    Hastings
    5,495
    My local branch of our favourite plumbing merchant now keeps them in stock. Last two were £10.45 plus the dreaded each, add on the cost of a tap extender if needed and it still works out a lot cheaper than a brass shanked fluidmaster.
    turnpin and SimonG like this.
  7. The Following User Says Thank You to Mike Jackson For This Useful Post:
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,695
    showing them in bes CISTERN & TANK - FLOAT OPERATED VALVES
    ifill Float Valve
    Unifill is a 4 in 1 inlet float valve that can be changed from bottom to side entry without using a blanking plug. Supplied with both 3⁄8" and 1⁄2" BSP threaded connectors.
    Part No. Description Unit Price Qty
    21546 SKYLO, unifill, plastic connectors £8.80
    21547 SKYLO, unifill, brass connectors £12.00
    turnpin likes this.
  9. The Following User Says Thank You to gas man For This Useful Post:
  10. #8
    ** UKPF Sponsor **
    Ray Stafford's Avatar
    Sep 2012
    Fareham
    10,089
    Quote Originally Posted by Mike Jackson View Post
    Good lord, so we do.
    You learn something new every day! Thanks Mike.
    Last I heard, Rob was still evaluating it. <memo to self - try to keep up>
    gas man and turnpin like this.
  1. Pegler float valve
    By eagleeye in forum Valves & Taps
    Last Post: 29-09-2013, 04:47 PM
  2. compact float valve
    By buckley plumb in forum Valves & Taps
    Last Post: 29-08-2013, 05:49 PM
  3. wc float valve
    By buckley plumb in forum Bathrooms, Showers and Wetrooms
    Last Post: 22-05-2013, 05:57 PM
  4. Ball valve/Float valve
    By Koogatubac in forum Valves & Taps
    Last Post: 22-08-2012, 11:30 PM
  5. Replies: 10
    Last Post: 02-10-2011, 10:12 AM
skylo unifill
unifill solution for tiles
content
viva skylo
brass connector for skylo unifill
