Plumbing & Plumbers Forum - H2 Panel.
  • 1 Post By SimonG
H2 Panel.
Discuss H2 Panel. at UK Plumbers Forums; Been wanting to try one of these for quite sometime and finally the opportunity arose. Purchased from Heating Innovations, it was the 22mm version. I thought the purchasing side was ...
    SimonG's Avatar
    16,035
    Default H2 Panel.
    Purchased from Heating Innovations, it was the 22mm version. I thought the purchasing side was a little weird as I had to write to them with a cheque. I had to answer 5 basic questions and state how soon I needed it. I needed it asap (dont we always) andcthought the order process would slow it up. It didnt though, the panel was received in less than a week of me posting the letter, so its 10 out of 10 for this part.
    My biggest surprise was how small, or shall we say compact, the panel actually is. It is very well built with very comprehensive instructions for installation, commissioning and use. It also comes with the dry pocket stat for the solid fuel burner and a cylinder stat.
    I had the luxury of installing in a decent sized location and mounted it on the wall on a couple of strips of 3 x 2 to give some clearance behind the panel.
    It was easy to pipe and wire, but the only down side is the position of the cylinder flow. It comes out of the centre of the panel at you. Have to be careful in the routing the pipework so that you dont affect the wiring centre or ability to change any of the motorised valves.
    I cant comment on its overall performance as the stove has not been installed, but is working fine through the external heat only oil boiler.
    I will be using it again.
    bigads28 likes this.
    SimonG's Avatar
    16,035
    Default Re: H2 Panel.
    A piccie i took whilst work was in progress. Not very good one though.
    Forum Thug
    croppie's Avatar
    23,718
    Please go to H2 Panel. for the discussion on this.
    Cheers for this Simon.
    Croppie
    (By the way, I'm commercial!)
  1. H2 Panel.
    By SimonG in forum Oil and Solid Fuel Forum
    Last Post: 01-05-2014, 05:27 PM
  2. Waterproof access panel in bath panel
    By johnst in forum New Member Introductions
    Last Post: 19-05-2013, 11:05 AM
  3. Old panel radiators
    By Mpb-10 in forum Central Heating Forum
    Last Post: 01-08-2012, 10:51 PM
  4. H2 panel
    By xpertbert in forum Oil and Solid Fuel Forum
    Last Post: 04-03-2012, 09:22 PM
22mm h2 panel
