Discuss Replace bath & shower mixer tap diverter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Anyone know how I get to the diverter valve in this? Cant see any obvious way to get the handle off that diverts between bath and shower. When on shower mode the tap is pouring out water at the same time. We've got a full bathroom refurb booked in for in 3 weeks so just need a temporary fix to get us by.
undo the hex nut infront of the handle ?
Doh, that looked like a show nut. Took the diverter out which was basically a bit of metal that moves some big white plastic thing up and down in the tap so there must be something wrong with the plastic bit but I can't get to that to see.
No one knows any quick bodge fixes that will tide us over for the next three weeks do they?
Have you tried just replacing any o rings and lubing it up ?
Couldn't see any O rings, just this white plastic bit behind the diverter head. I'm guessing you must be able to take the top bit of the tap off that doubles as a shower head holder to see the plastic bit inside but felt very solid when I tried to turn it
Reply to Replace bath & shower mixer tap diverter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
