Go Back   Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK > Plumbing Forums > Plumbing Tools
Plumbing Tools Discuss all aspects of the many plumbing tools available today.
Old 02-08-2008   #1 (permalink)
pt44
View pt44's Photo Album
Default Removing Old Olives
Hi
1st post - so be nice to me
I often have to remove old olives - and keep thinking to myself - there must be an easier way to do this? Is there any kind of special tool on the market or maybe a technique that I haven't thought of?
Currently I use the following method. Not very technical - but I'm no pro.
Bash the back of the nut against the olive - using an adjustable wrench around the pipe. If the olive is fairly new - this tends to remove them. However, if they are old and have been squeezed too hard - they don't budge. So my next step is usually to cut the pipe shorter and make good by adding a new section of pipe. This works, but often there is not much room for manoeuvre, so wondered is there is a better way?
Paul
pt44 is offline   Reply With Quote
Old 02-08-2008   #2 (permalink)
ajs heating
Posts: n/a
Default Re: Removing Old Olives
buy an olive puller.
example.
http://www.monument-tools.com/images2006/prodlistimages/olive_puller_2036t.jpg
their is a few different types of puller.
or you can cut the olive with a junior hacksaw but be careful not to cut the pipe.
if the olive is squashing into the pipe the it may be best to fit a new section as a new olive won't seal if the pipe is to damaged.
Old 02-08-2008   #3 (permalink)
uug197h
View uug197h's Photo Album
Monument 2030B Olive Removing Tool 15mm - 2030B - MON2030 - Monument Other Accessories
these are ok but you would need two 22mm and 15 mm
Plumbing Forum Moderator
Old 02-08-2008   #4 (permalink)
Alanka
View Alanka's Photo Album
I have a dual-size olive puller (15/22 mm) that is useful, from Monument I believe. Not cheap, but much cheaper than buying one of each size. (Toolstation for £15.60 inc VAT)
An alternative (useful if you can't access the olive with the above puller) is an olive cutter. I've got two of those -- 15 and 22 mm -- also from Monument I think. (Toolstation). Not cheap at nearly £24 each!
But sometimes none of these tools work, and you end up hacking it off with a junior hacksaw anyway!
Cheers,
Big Al
Old 03-08-2008   #5 (permalink)
pt44
Thanks for the excellent replies.
So I presume that the with the removal tools, you clamp them on and twist them back and forth - and they cut the olive somehow? Is that correct? Is it easy to use, without damaging the pipe?
I think I understand the hacksaw technique. I've watched my dad do it many times, but not tried it myself for fear of cutting the copper. Which with my clumsiness is very likely.
The puller tool looks neat - but presumably only works if they are not too bedded in. Plus, if I have to buy a removal tool, then that would cover both aspects? Or does the puller manage to remove a good percentage of them without the need to cut them?
Paul
Old 03-08-2008   #6 (permalink)
ajs heating
Posts: n/a
http://www.ukplumbersforums.co.uk/re...ller_2036t.jpg
i always use this one never failed me yet unless the olive you are removing has an old imperial nut behind it.
or mot valve nuts which are a different thread
Olives Brass or copper bigb1970 Fittings & Pipes 4 24-08-2008 12:09 PM
