5.9015, 5.9022 - Rothenberger PLASTICUT 15mm - 22mm Plastic Tube Cutter
Simply click the PLASTICUT into place and grip FIRMLY, rotate around the pipe in the direction of the arrows. The pipe will be cut, squarly and cleanly after 1 - 2rotations.
* Simple to use
* Single - handed cutting action
* Ideal for confined spaces
* Safer to use than saws or shears
* Tailor made for professtional and DIY use
* Clean, square cut through all types of plastic pipe
* Comprehensive size range available
* Replacement blades available
* SAFETY NOTE Please replace safety insert after use
http://www.tradecounterdirect.com/pr...20Cutters&pg=1
