Page 1 of 3 123 LastLast
Results 1 to 12 of 36
Plumbing & Plumbers Forum - Blow Torch, which one?
Like Tree7Likes
Discuss Blow Torch, which one? at UK Plumbers Forums; Hi all, Looking at buying the Rothenberger Superfire 2 but have read quite a few mixed reviews. Can anyone let me know what is a decent torch to buy and ...
    Oct 2009
    1,116
    Default Blow Torch, which one?
    Hi all,
    Can anyone let me know what is a decent torch to buy and whether propane or MAPP is best?
    Cheers
    stevetheplumber's Avatar
    east london
    10,613
    Default Re: Blow Torch, which one?
    Quote Originally Posted by nysk2008 View Post
    Hi all,
    Cheers
    superfire 2is good just keep it clean and dont drop it mapp burns hotter than propane but is more exspensive
    ADMINISTRATOR REDSAW's Avatar
    Jan 2009
    Nottingham
    13,334
    got a few.
    rottenburger 2 = northsea oil rig piper alpha blow off.
    quick fire 2 = b&q £25 ish, and i prefer this one for general work with propane/mapp for outside work.
    ¿ʞɹoʍ sɐƃ
    dontknowitall's Avatar
    Apr 2008
    Herefordshire
    6,122
    If you're a plumber and working with builders and other trades, they'll give you more respect if you have a Rothenberger rather than a cheapie shed model.
    Same applies to others tools - would you trust a carpenter who turned up with a Draper 12 volt drill?
    I've had various torches. I prefer the Superfire 2 to all the others. Can't say I've really had a problem with it, other than having to tighten up the allen key screws regularly, but that's probably due to the abuse it gets in the back of the van.
    layzee D likes this.
    Robtheplumb
    Quote Originally Posted by dontknowitall View Post
    Shouldn't make any differance what name is on your tools, I know a chippy who gets everything from the sheds, got a b&q drill, focus jigsaw...top notch chippy, I also know a chippy who has everything dewalt, dumb twonk can't even hang a door! A tool is as good as the bloke on the end, you get respect by being good at what you do.
    As for the blowlamp, I have just got the rothenberger to replace my bullfinch, still like the bullfinsh but the roth is a better tool for the job. Was soldering today on some 28mm outside with the roth on mapp gas, not a problem even in the wind but I wouldn,t have done it with the bullfinch.
    Jan 2009
    Nottingham
    13,334
    these are the torches i use,
    the roth cost me £60 and i hardly use it because of the big flame/tight corners etc.
    the bernzomatic quickfire is my fav to use.
    and the simplest @ £17 is the standard that all the old boys use that i see anyhow.
    Attached Thumbnails Attached Thumbnails Blow Torch, which one?-roth.jpg   Blow Torch, which one?-ts3000t_lg.jpg   Blow Torch, which one?-prm9gskit.jpg
    ¿ʞɹoʍ sɐƃ
    Oct 2009
    1,116
    Cheers everyone for your responses. Decided to go with the Roth
    May 2009
    7,301
    It sounds like the clothing mentality is coming to our tools,we will all be expected to have designer tools soon to get trade cred,with our £ 80 little niki pipe slice , £ 120 ralf lauren pipe grips and £2000 celvin klein flushing unit
    I have a Rothenberger superfire 2 because it is a very good touch but if next time I need one and they do a cheaper make somewere,thats just as good ,that will do me
    Most of my tools are standard stuff,mainly because alot goes walkies or is stolen,I bought a cheap drill for my 4" core bit about three years ago for £45,still going stronge,no trade cred when I pull it out though
    uplands50 likes this.
    Apr 2008
    Herefordshire
    6,122
    I must admit I have been surprised by how much comment by people I've worked with at jobs, on some of my tools which is why I mentioned what I did further up.
    Wish I hadn't mentioned it on this forum now!!!
    I felt when I started plumbing that as long as I had good enough tools (irrespective of price), they'd do for me, but I've been embarrassed on occasion with what others have said about my stuff. Perhaps it's more to do with me cleaning my tools and toolboxes every so often? I do that because a) I like to look after my stuff and b) if I turn up to a customer's house I feel much more comfortable about plonking stuff on their floor if my kit is clean. I feel it gives the impression that if I look after my stuff, they'll feel I'll look after their house and possessions.
    For the record, I have a Rothenberger Superfire 2, an 18v DeWalt drill, a couple of expensive wrenches/adjustable spanners and much of the rest is cheap but perfectly functional (eg a screwdriver set with loads of attachments that cost me £10, a jigsaw that cost me about £15, etc.)
    Jul 2009
    dann sarf
    222
    I use the rothenburger 2, the torch heads last me about 2 years. I do buy decent gear after research. For instance, will only use bacho adjustables, keep them clean and keep my eye on them, check my tool bag every time I leave a job. Hate cheap power tools, watch builder buy cheap drivers for a job, they fail, they buy a new one, charge goes to customer, no real torque control, srcew heads ripped off, pozi heads damage, whats the point. Buy trusted tools and look after them, they'll make your life easier.
    By the way do any of you have tools but dont use them, my wife bought me a set of multi steps, they're good, but I leave them at home and still use my normal steps on the van. I think about this yet still carry on.
    alexclark
    Quote Originally Posted by radswilldo View Post
    I couldn't agree more, we are professional trades men and so should be using professional tools not DIY tools you can buy from B & Q, treat your tools with respect, keep then cleaned and they will look after you. You get what you pay for so the extra money is in fact an investment, in my opinion.
    Image and first impression is everything in our industry, if you make a good impression on the customer you will get further business...of course you have to do a good job too.
    little things like being polite, not swearing, wiping your shoes as you come in, lay dust sheets, present your tools nicely...etc etc does not go unnoticed.
    back on topic, Go for the Roth Superfire 2, you wont regret it.
    Alex
  1. Whats the best Blow Torch to get?
    By jimmock in forum Plumbing Tools
    Last Post: 30-09-2014, 09:46 PM
  2. Blow torch safety
    By dazplum in forum Plumbing Forum
    Last Post: 15-05-2013, 10:49 PM
  3. Blow off
    By AllyBongo in forum Gas Safe Register Forum - Public Forum
    Last Post: 17-10-2012, 10:29 PM
  4. blow torch
    By hunterseye in forum Plumbing Tools
    Last Post: 09-08-2012, 01:04 AM
  5. Best blow torch?
    By cosworth*mad in forum Plumbing Tools
    Last Post: 01-01-2011, 08:20 PM
  6. Blow Torch
    By Spudhater in forum Plumbing Forum
    Last Post: 16-07-2010, 12:05 AM
  7. Pipe bender & blow torch
    By Jamie Banks in forum For Sale & Wanted
    Last Post: 06-02-2010, 01:43 AM
  8. Blow torch adaptor question
    By [email protected] in forum Plumbing Tools
    Last Post: 19-01-2010, 10:36 AM
  9. blow off
    By REDSAW in forum Plumbing Forum
    Last Post: 17-11-2009, 08:22 PM
  10. Blow torch problem
    By Winston in forum Plumbing Tools
    Last Post: 01-11-2009, 12:30 AM
rothenberger superfire 2
rothenberger blow torch
rothenberger torch
which blow torchblow torch reviews
