Results 1 to 15 of 17
Plumbing & Plumbers Forum - hole saw kits
hole saw kits
Discuss hole saw kits in the Plumbing Tools at Plumbers Forums; Hi, which hole saw kit would you recommened please, for general plumbing? looking at £50-£60 bracket. Matt...-
10-08-2012 #1New to Plumbing Forum
- Aug 2012
- 15
hole saw kits
Matt
10-08-2012 #2Plumbers Arms member
- Jun 2011
- Wymington
- 139
- 13
- Thanked 14 Times in 13 Posts
Re: hole saw kits
No need to spend that much. He's one for half the price:
ROTH PLUMBERS 9 PCE HOLESAW KIT 114202 C | Heating Supplies | Plumbing Supplies | Plumbing Tools
10-08-2012 #3Plumbers Arms member
- Jun 2008
- Nottingham
- 1,064
- 20
- Thanked 107 Times in 98 Posts
Re: hole saw kits
I've got this Bosch one and it's good enough for me
BOSCH 9 PIECE HSS BIMETAL PLUMBERS HOLESAW SET 19MM - 57MM & PILOT DRILLS BNIB ! 3165140641708 | eBay
10-08-2012 #4UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
Re: hole saw kits
what ever kit you buy ill gaurantee it will not contain the size you wont and youll have to buy an extra cutter
10-08-2012 #5
Re: hole saw kits
This is the kit I've got Starrett KS2000P Plumbers Holesaw Kit
10-08-2012 #6Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,033
- 232
- Thanked 101 Times in 97 Posts
Re: hole saw kits
Hack/Hole Saws & Tap Reseaters
This is my one and its yet to fail me, has all the right sizes including the all important bath tap drilling one.
10-08-2012 #7Plumbing Forum Contributor
- Dec 2011
- 54
- Thanked 5 Times in 5 Posts
Re: hole saw kits
The Bosch hole saws are great, they seem to last a lot better than the cheapy ones as well.
18-08-2012 #8Banned
- Dec 2009
- Portsmouth
- 672
- 64
- Thanked 70 Times in 68 Posts
Re: hole saw kits
Bosch or Starret at a minimum.
The cheapo ones are ok if you are going through soft stuff, ie plasterboard fascia etc.
Try one a worktop or astracast sink, and it will have less teeth left than Shane Macgowan!!
18-08-2012 #9Plumbers Arms member
- Dec 2011
- Somerset
- 1,740
- 93
- Thanked 177 Times in 173 Posts
Re: hole saw kits
I have recently upgraded from a toolstation jobbie to a rothenburger set and have been suitably impressed.
18-08-2012 #10Moderator
- Feb 2010
- Alloa, Scotland
- 7,066
- 745
- Thanked 672 Times in 573 Posts
Re: hole saw kits
I recently bought the Bosch set which has a quick change function and it's brilliant. I used the 50mm one on a cast iron gutter to cut an outlet and it went through it no problem and still remained sharp and usable. The Bosch carbide hole saws are the best in my opinion.
Bathroom Design & Installation Specialists.
Over 34 years experience.
Rated People 5 Star Rating.
BY THE WAY I'M NOT COMMERCIAL. A flexible hose, gets up ma nose.
18-08-2012 #11
19-08-2012 #12
Re: hole saw kits
I've had a bosch Bi-metal set for a while and must say im more than pleased.
20-08-2012 #13** UKPF Sponsor **
- Sep 2008
- Hoddesdon
- 327
- 16
- Thanked 13 Times in 10 Posts
Re: hole saw kits
For drilling stone this is the PORSADRILL all in one system, for granite, marble, stone, glass, tiles, porcelain, travertine, pottery, slate.
Sizes accept all gas pipes (22mm and 28mm) copper 15mm pipes, 40mm and 32mm waste outlets.
Plus a selection of cores for 6mm and 8mm rawl plugs
Packs are marked out with what the cores do, and full instructions on the back of the pack.
Only works in STONE
Does not work on steel
Does not work on wood
Does not work on plasticLast edited by 365drills; 20-08-2012 at 05:30 PM.
Richard Hazell
w: http://www.365drills.com
t: 01992 410636
e: info@365drills.com
Commercial Diamond Drills for VERY hard stone
Decent reliable gear that wont let you down
23-09-2012 #14New to Plumbing Forum
- Sep 2012
- 11
Re: hole saw kits
I have a tendency to just buy the sizes I need and a couple of arbors. I'd like some more suited to metal with more and finer teeth but haven't found any that suited yet.
23-09-2012 #15Steady Plumbing Forum Contributor
- Sep 2012
- South Wales
- 231
- 23
- Thanked 16 Times in 15 Posts
Re: hole saw kits
The Lenox brand are real good quality, you need to keep dipping them in cutting oil if you are to be drilling through metal girders etc.
Freezing Kits
By WaterTight in forum Plumbing ForumReplies: 15Last Post: 17-02-2013, 09:04 PM -
Plume kits??
By dylski in forum Gas Safe Register Forum - Public ForumReplies: 3Last Post: 13-07-2012, 12:36 AM -
Bylaw kits
By scotty plumber in forum Plumbing ForumReplies: 11Last Post: 31-05-2012, 11:22 PM -
freeze kits
By pipeline in forum Plumbing ForumReplies: 14Last Post: 30-12-2011, 04:41 PM -
plume kits
By Eddie Charlton in forum Valves & TapsReplies: 7Last Post: 23-12-2010, 10:50 PM
3Likes
HALL of SHAME PHOTo`s
9 Minutes Ago in General Off-Topic Chat
