Results 1 to 8 of 8
Plumbing & Plumbers Forum - shower tray not emptying quick enuf
Discuss shower tray not emptying quick enuf in the Plumbing Tools at Plumbers Forums; my shower tray don seem to emty very kwik i did pour some drain cleaner down there, and it do swirl more now ... every now and then it do ...-
10-05-2012 #1Plumbing Forum Contributor
- Jan 2012
- 82
- 32
my shower tray don seem to emty very kwik i did pour some drain cleaner down there, and it do swirl more now ... every now and then it do not swirl and stops swirling why is tihs.... somebody said to me today to put your foot on the shower oultet now and then and pump it... will tihs help it swirl more... and go down bettrer...?
plaesas advise...
10-05-2012 #2UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Have you removed the hair collector from the trap
It usually pulls out. Some times you will have to turn it slightly to get it out.
This can help. Once you have done this. It may be good to flush some more water down to free up and wash away any other debris.
If you still having issues. It may be best to call a local plumber in. You can post on the looking for a plumber forum for someone local to come to your aid
"nothing is impossible"
The Following User Says Thank You to SimonJohns For This Useful Post:
handsomejackuk (10-05-2012)
10-05-2012 #3Plumbing Forum Contributor
- Jan 2012
- 82
- 32
Re: shower tray not emptying quick enuf
my dorta do take out the chrome plugger all the time becos she thinks it do help the water to flow down but i thikn it does clog more with it out..... i wos wundering if i could use my compressor too blast out all the muck is this doable....
i have a real long tube from my shed from my compresor... can i do this ok ? if i make up a seal to use on the plugger...and blow it all out...
10-05-2012 #4UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
I wouldn't suggest such a high pressure of air. You may risk damaging pipe work or fittings.
Could you post a picture of the waste. We may be able to advise if there is another component to remove
If you do post a photo. Do one with chrome part on. And one with chrome part removed."nothing is impossible"
10-05-2012 #5Plumbing Forum Contributor
- Jan 2012
- 82
- 32
thanx but.... i got my air bag from mah compressor on a tapered door stop and blasted 150psi down the sucker... all the crud seems to be gone now and it does swirl a lot bettrer... i keep it clean now with costic too... thanxs for hte help...
10-05-2012 #6Plumbers Arms member
- Jan 2012
- Essex
- 3,202
- 80
A great thread, made I laugh, possibly inappropriately.
My mind couldn't get rid of the age of Joe Dolche singing 'shuttup a your face'Proud to be 'Part P', the world is now my mollusc!
10-05-2012 #7Plumbers Arms member
- Mar 2012
- Bolton
- 926
- 28
- Thanked 97 Times in 94 Posts
The hair collector is there to prevent blockages, I'd tell your dorta to leave it alone
11-05-2012 #8Steady Plumbing Forum Contributor
- Apr 2010
- Lancashire
- 104
- 12
- Thanked 4 Times in 4 Posts
wow lol glad its fixed but wow
Big shower tray
By RobinClay in forum Bathrooms, Showers and WetroomsReplies: 10Last Post: 02-10-2011, 12:01 AM -
Price on installing a ceramic 900mm quadrant shower tray and fitting shower cubicle?
By nick99 in forum Bathrooms, Showers and WetroomsReplies: 4Last Post: 29-05-2011, 04:14 PM -
Shower tray
By marsaday in forum Bathrooms, Showers and WetroomsReplies: 4Last Post: 19-03-2011, 01:04 PM -
Emptying Oil Tank
By 33ching in forum Plumbing ToolsReplies: 4Last Post: 17-08-2009, 10:05 AM -
shower tray
By sasik in forum Plumbing ForumReplies: 4Last Post: 09-05-2009, 08:42 AM
1Likes
Williams & Co product review...
39 Minutes Ago in General Off-Topic Chat
