Results 1 to 12 of 16
Plumbing & Plumbers Forum - Tips for making copper pipes round again?
Discuss Tips for making copper pipes round again? at UK Plumbers Forums; Hi Folks, Do any of you have any tips or know of any tools that can make 15mm/22mm pipes round again at the end that will fit into a compression ...
    Sep 2010
    32
    Default Tips for making copper pipes round again?
    Hi Folks,
    Do any of you have any tips or know of any tools that can make 15mm/22mm pipes round again at the end that will fit into a compression joint?
    I am having to "manufacture" a bespoke couple of pieces of 22mm to 15mm pipe with the pipe centres completely offset to the maximumum, and during the process (using a vice and a hacksaw!) the ends are a bit oval and I need to make them as perfectly round as possible.
    hants
    232
    Default Re: Tips for making copper pipes round again?
    take a female compressin fitting of the size you are using , remove nut and olive and knock onto end of pipe gently untill fully on.
    :cool:46:cool:
  3. The Following User Says Thank You to ferret For This Useful Post:
    Nov 2009
    In and around Surrey and the Home Counties
    73
    Try a Re-Rounding tool, or buy a socket former and only use the front part.
    Monument make them.
  5. The Following User Says Thank You to JJayMan For This Useful Post:
  6. #4
    May 2010
    sudbury suffolk
    121
    i had to do this the other week was changing a mono block tap which got from screw fx and when i pipe sliced the tails down to suit what i wanted the pipe slice squashed the tails so it was just lucky the old taps were cross head so managed to re shape the end of the copper tails with the cross part of the tap
  7. #5
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    3,669
    DO you mean this is happening as you bend it?
    Can you bend it beofre you cut it
    if not pop and insert in the end before you bend it
    Regards
    Tom
  8. #6
    Jun 2010
    Wiltshire
    146
    I've used a socket former on plastic pipe for jointing.
    But how well does it work for rounding copper pipe, I assume you'd heat the end of the pipe so it's more plyable though you obviously don't do it too much as you don't want to widen it.
    But does it work o.k.
  9. #7
    May 2010
    sudbury suffolk
    121
    hi no i ment cheep copper tails which squashed when i twisted the pipe slice round to cut them
  10. #8
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,921
    that's happened to me too
    The Turtle Moves
  11. #9
    Dec 2011
    Use an adjustable spanner
    1 adjust it to the slimmer part of the diameter of the pipe
    2 keep rotating it until its round again.
    That simple i hope this helps.
  12. #10
    dontknowitall's Avatar
    Apr 2008
    Herefordshire
    6,122
    Using a hacksaw nearly always leaves a burr which makes fittings tricky to fit but I find that usually a file and pump pliers is enough.
  13. #11
    SimonJohns's Avatar
    Bridgend, Wales
    4,588
    Default
    Use a swayger(can't spell it).
    "nothing is impossible"
  14. #12
    ADMINISTRATOR REDSAW's Avatar
    Jan 2009
    Nottingham
    13,254
    Quote Originally Posted by carpstu View Post
    put a new cutting wheel in.
    ¿ʞɹoʍ sɐƃ
  1. Hot/Cold pipes the wrong way round??
    By martinbliss in forum Plumbing Forum
    Last Post: 03-08-2015, 08:49 PM
  2. Pipes making banging noise?
    By bewsh in forum Central Heating Forum
    Last Post: 28-06-2013, 10:44 PM
  3. Why replace old 3" iron pipes with small copper pipes?
    By mandries in forum Plumbing Forum
    Last Post: 25-04-2013, 05:29 AM
  4. Soldering non copper pipes
    By Irish in forum Central Heating Forum
    Last Post: 31-07-2012, 10:03 PM
  5. Soldering Copper Pipes
    By diy_monkey in forum Central Heating Forum
    Last Post: 06-08-2011, 11:09 PM
  6. Help with buried copper pipes
    By shneld in forum Central Heating Forum
    Last Post: 11-10-2010, 03:42 PM
  7. what's the best insulation for copper pipes
    By katalin in forum Plumbing Forum
    Last Post: 06-10-2010, 05:40 PM
  8. Copper Pipes in New Build
    By adh in forum Fittings & Pipes
    Last Post: 23-06-2010, 09:46 AM
  9. rendering around copper pipes
    By CHRISTO in forum Plumbing Forum
    Last Post: 30-11-2009, 05:55 PM
  10. Mixer tap pipes wrong way round???
    By reddwarf123 in forum Plumbing Forum
    Last Post: 01-05-2008, 01:36 PM
tool to reshape cooper pipe
how to reshape copper pipe
how to round a copper pipe
how to make copper pipe round again
copper pipe socket formers
