Re: please help as im confused on a certain question?
It is confusing isn't it!
The pressure exerted by water at the bottom of a vessel depends ONLY on the depth, not the volume or any other tank dimensions. So the pressure at the bottom of a 1m long vertical 15mm pipe full of water is exactly the same as the pressure at the bottom of a swimming pool at the 1m end: that is 9.81kN/m2 (9.81kPa)
1 metre of water depth exerts a pressure of 9.81kN/m2 (9.81kPa, about 0.1bar). So 1.6m depth exerts a pressure of 1.6 x 9.81kN/m2 = 15.70kN/m2 (15.70kPa).
So your first calculation is the correct one!
(A rough guide is that 1 atmosphere, i.e. 1 bar, or 100kPa, equals about 10m of water head.)
