Results 1 to 9 of 9
Plumbing & Plumbers Forum - 2-button Flush .... what to press?
Discuss 2-button Flush .... what to press? in the Plumbing Forum at Plumbers Forums; My 'new' toilet did not come with any instructions. I asked the 2 fitters (the one who installed it, and the second one who replaced the faulty pan) what the ...-
12-05-2010 #1New to Plumbing Forum
- Jan 2010
- 9
I asked the 2 fitters (the one who installed it, and the second one who replaced the faulty pan) what the two buttons did. I was aware that this should operate a half-flush and a full flush, but did not know which button or which button combination should do what ....
I got 2 responses, from the first that "...the small button is only there to help the larger button pop out ... and no it wasn't a 2-button flush system since there was only one cable from the panel"
The second statement was "...you need to press both buttons together to get the larger flush"
The cistern and panel seem to correspond to a Macdee cistern and dual button panel (duo-compact cistern and front access fascia). The panel has one small button surrounded by a larger button.
I emailed Macdee ... and got zero response.
ps ... I cannot tell any difference in flush volumes between pressing the small button, pressing the larger button and pressing both buttons ... so maybe I have been short-changed on the cistern?
cheers!
12-05-2010 #2
Re: 2-button Flush .... what to press?
one for half flush and one for full flush
12-05-2010 #3Plumbers Arms member
- Sep 2008
- Plymouth
- 504
- 3
- Thanked 10 Times in 10 Posts
one for a wee and two for a poo
12-05-2010 #4Plumbers Arms member
- May 2009
- 7,302
- 218
- Thanked 683 Times in 604 Posts
Just pulled out instructions
Use 1 for a small poo 2
And if you have a poo and do'nt know what to do,go for the 2
Do 2 if you have a wee and follow through with a poo
If your not sure what hit the floor ,hit 2 as it maybe a poo
Use 1 if you do'nt need to wipe your bottom,always use 2 if all above is forgotten
Hope this helps
The flushes should be the same,as said one will be longer than the other if syphon set up correctly
imho
13-05-2010 #5New to Plumbing Forum
- Oct 2009
- 22
haha was nearly crying reading puddles explanation ...very good !!
13-05-2010 #6Plumbers Arms member
- blackpool
- 2,139
- 4
- Thanked 10 Times in 8 Posts
what do you press if you know somethings come out - but didnt feel it ?
OP smaller button small flush
bigger button big flushShaun, GS 233006, Engineer 2485197
14-05-2010 #7New to Plumbing Forum
- Oct 2009
- 22
what you mean a phantom flush ?
14-05-2010 #8Plumbing Forum Contributor
- Oct 2008
- 40
mine got a spew up button too
17-05-2010 #9New to Plumbing Forum
- Jan 2010
- 9
Many thanks for all your replies !
What is this type of WC flush?
By cattlegrid_79 in forum Plumbing ForumReplies: 14Last Post: 02-12-2009, 07:15 PM -
New flush required, but which to buy???
By LouToo in forum Sanitary WareReplies: 5Last Post: 23-11-2009, 03:58 PM -
Flush Plates
By Aled in forum Plumbing ForumReplies: 1Last Post: 25-08-2009, 12:54 PM -
Pnuematic Flush not working
By Paulgolfer in forum Sanitary WareReplies: 4Last Post: 24-02-2009, 10:00 AM -
No instructions for push button cistern (with pics)
By jgw1 in forum Plumbing ForumReplies: 6Last Post: 02-02-2009, 11:46 AM
Holidays
