Results 1 to 12 of 13
Plumbing & Plumbers Forum - what thread is this shower wall elbow?
Like Tree2Likes
Discuss what thread is this shower wall elbow? at UK Plumbers Forums; I have a white plastic shower wall elbow thats yellowed and I'd like to swap it for a chrome one. I bought a 'generic' cheap one off ebay, but its ...
    Default what thread is this shower wall elbow?
    I bought a 'generic' cheap one off ebay, but its way too small.
    The thread is a hair under 26mm, so pretty much one inch. This seems to translate to 3.4bsp.
    Is this standard for shower wall elbows?
    Member Matchless.plumb's Avatar
    Sep 2015
    915
    Default Re: what thread is this shower wall elbow?
    Quote Originally Posted by nick9one1 View Post
    Hello and welcome along,
    Have you got any pictures by any chance?
    Regards ron
    Sep 2015
    915
    Regards ron
    ...Yep sure
    ...Yep sure
    Click image for larger version.
    Mar 2013
    1,487
    Think,from photo. you may be measuring it wrong. Seems you are starting from 5mm which instead of 26mm would give 21mm and this equates to 1/2" BSP. Check by seeing if any 15mm compression fitting will screw in once nut and olive removed.
    Sorry misread photo. 3/4"BSP is 26.44mm overall and unlike 1/2" BSP does not equate to thread on 22mm compression fitting.
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    8,104
    Looks like 3/4" BSP from the rule photo, more concerned about how you going to know if that rubber joint leaks afterwards being buried behind the tile.
    Just looked again and reckon the sealing O-ring is missing and PTFE tape has been used on the threaded male instead, up to you Nick but wouldn`t want to my name on that job.
    Matchless.plumb likes this.
    yes, thats what I thought.
    I think I might have to get something like this..
    (3/4 bsp male to 1/2 bsp female)
    then use a standard 1/2 bsp elbow.
    I cant find any elbows in 3/4 bsp.
    10,219
    Sep 2015
    915
    As mentioned above, you should be more concerned if it's water tight once it's buried in the wall ... maybe changing the whole lot ... plastic will worn out very fast and in my experience the seal isn't and threads aren't as good ..
    Quote Originally Posted by Matchless.plumb View Post
    Its been water tight so far (id guess 10 years), I used ptfe tape last time I removed it.
    I managed to find a 3/4 bsp to 1/2 bsp flush adaptor on eBay which has worked a treat.
  1. 22mm compression elbow wall plate fixings
    By Anthony Pipes in forum Plumbing Forum
    Last Post: 02-04-2016, 10:23 PM
  2. Positioning a wall plate elbow for a bath spout
    By Andy26 in forum Bathrooms, Showers and Wetrooms
    Last Post: 13-12-2014, 11:01 AM
  3. quick question about wall plate elbow
    By reeves1985 in forum Plumbing Forum
    Last Post: 13-10-2014, 11:09 PM
  4. Bib tap not upright on wall elbow plate
    By catfishBOB in forum Valves & Taps
    Last Post: 05-02-2014, 04:31 PM
  5. Replies: 2
    Last Post: 28-03-2010, 12:15 AM
