Results 1 to 12 of 12
Plumbing & Plumbers Forum - Chrome sink waste into 32mm solvent 90
Like Tree2Likes
  • 1 Post By Plumbstar Tom
  • 1 Post By 1animal1
Discuss Chrome sink waste into 32mm solvent 90 at UK Plumbers Forums; I have the above problem after having done all my en suite piping in solvent weld due to the majority of connections being hidden away under tiles - only 1x ...
    Aug 2015
    146
    Default Chrome sink waste into 32mm solvent 90
    I have the above problem after having done all my en suite piping in solvent weld due to the majority of connections being hidden away under tiles - only 1x 40mm T piece in the wall prior to entering the soil stack, converted to 32mm for the sink which is 800mm above it - yet to test before building around.
    I have dug out a block wall ready to accept the 32mm solvent pipe but am struggling to find a solution to fit the chrome pipe into the solvent 90 exiting below the sink. The chrome pipe has a reduced end for push fit, and a wide end for the trap - the wide end when inserted is approx 3mm out around the diameter. I am thinking that i could either source one of these McApline chrome 90's with compression and solvent fitting integrated.... or find another solution to seal the pipe closing this 3mm gap with possibly ptfe tape? bit back street but the 90 will sit flush with the tile, so it would make it more serviceable in the future as i won't be able to get to the Mcalpine compression fitting...thoughts?
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,127
    Default Re: Chrome sink waste into 32mm solvent 90
    Photo's?
    Might make it easier to think of a solution
    Aug 2015
    146
    There's nothing to photo as of yet - only a wall with a channel ready to accept the 32mm pipe which will require a 90 at the top, where it will meet the chrome waste pipe...the 90 will be flush with the tile once i have dot and dabbed new plaster board and tiled....
    Previously I've used push fit - so when setting the 90 going into the wall, flush.... you can just push everything into place once tiled (chrome pipe from waste). I wanted to make this more robust, removing the question mark that is the rubber seal which i imagine can and will fail eventually when compared to solvent...
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,840
    All I`ll say is taking up a 3mm gap with PTFE and hiding a compression joint behind tiles is asking for trouble. Or have I misread the situation?
    Aug 2015
    146
    Not at all - those are my only 2 options at this point - I feel the best route is the solvent 90 exiting the wall. I just need to some how get a seal around the chrome pipe that is entering the solvent 90.
    The second option is the McAlpine 90 which has one end that is solvent, the other is a chrome compression - but I'm not sure if it'll be compatible with the floplast pipe i've used and if the chrome compression part will come out of the wall enough to service (as the waste needs to be able to be removed easily as fitting a work top with counter top sink - the counter will needs to be removable for maintaining the built in cistern)
    McAlpine Bend | Plumb Center
    9,673
    Compression 90
    AlexGas's Avatar
    Sunny Southampton
    2,870
    Quote Originally Posted by 1animal1 View Post
    Love McAlpine ... here's the fitting you need:
    McAlpine Adaptor | Plumb Center
    Make it happen!
    Aug 2015
    146
    Thanks Alex, that's the one i linked above. Do these mate to floplast solvent ok?
    I also notice they supply a 32mm and 35mm seal ring which is very helpful...
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    3,659
    Cannot see why it won't
    AlexGas likes this.
    Regards
    Tom
  10. The Following User Says Thank You to Plumbstar Tom For This Useful Post:
    AlexGas's Avatar
    Sunny Southampton
    2,870
    Any solvent weld is good to go.
    Make it happen!
  12. The Following User Says Thank You to AlexGas For This Useful Post:
  13. #11
    AlexGas's Avatar
    Sunny Southampton
    2,870
    They do an elbow too if it helps
    ... love it!
    Make it happen!
  14. The Following User Says Thank You to AlexGas For This Useful Post:
  15. #12
    Aug 2015
    146
    That's the one I've ordered, cheers Alex!
    I was worried that once I've boarded the wall and tiled I'd not have enough protrusion to turn the compression end (nothing worse!). I'll have to be a bit creative with my tiling depending on how far it sticks out.
    AlexGas likes this.
  1. sink on long 32mm waste run
    Last Post: 30-08-2014, 09:49 PM
  2. Chrome bath waste to solvent weld fitting !
    By Monkey Wrench in forum Fittings & Pipes
    Last Post: 13-03-2013, 09:31 PM
  3. Replies: 3
    Last Post: 17-10-2011, 09:09 PM
  4. Chrome Waste on sink
    By MickBrown in forum Plumbing Forum
    Last Post: 06-12-2010, 11:07 AM
  5. Kitchen sink waste-to-trap connector 32mm??
    Last Post: 27-07-2010, 07:07 PM
