Plumbing & Plumbers Forum - HELP PLEASE – Plug mechanism is broken
Discuss HELP PLEASE – Plug mechanism is broken at UK Plumbers Forums; I could do with some advice please. My bath has an overflowand plug, which lifts when you turn a handle. Not particularly unusual, I know. The handle has stopped twisting, ...
    Jan 2014
    12
    Default HELP PLEASE – Plug mechanism is broken
    The handle has stopped twisting, meaning I can’t lift theplug. For a long time the handle didn’t lower the plug (I just pushed it down)but now it won’t go up either.
    I’ve unscrewed and removed the handle and tried to turn thebar that the handle turns, but it only rotates about an 8th of afull circle. I have tried a bit of force but it won’t go any further. I couldgive it a fair bit of force, but might break it!
    Do any of you have any ideas what has gone wrong? Any suggestions?Should I take the overflow off? Should I check the cable? If do how? So manyquestions.
    Cheers,
    Dave
    Jun 2012
    London/Kent
    4,014
    Default Re: HELP PLEASE – Plug mechanism is broken
    Time for a new one Dave.
    You can buy a full replacement one.
    ADMINISTRATOR REDSAW's Avatar
    Jan 2009
    Nottingham
    13,334
    cables corroded or broke.
    there £25 upwards.
    if you like to fiddle then you can strip and replace with abike brake cable for a couple of quid
    ¿ʞɹoʍ sɐƃ
    Jun 2012
    London/Kent
    4,014
    http://www.screwfix.com/p/pop-up-bath-waste/27022
    You need to shop at Screwfix Red, £15 not worth the mucking about.
    Jan 2014
    12
    Thanks guys. Oh no, I definitely don't like to fiddle. I'll happily get a new one! Just wanted to check that I didn't do something unnecessary.
    Jan 2014
    12
    One follow up question - is it likely that I'll have to replace the plug too? Or can I get away with just replacing the cable and overflow bit? I could do without ripping out the actual plug if I can help it.
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,963
    most likely you will have to change the whole unit top and bottom parts as one
    The Turtle Moves
  1. Sprung loaded bath plug hole - broken?
    By Kendra123 in forum Bathrooms, Showers and Wetrooms
    Last Post: 23-11-2016, 10:35 PM
  2. Replies: 7
    Last Post: 10-02-2016, 05:52 PM
  3. Bathroom overflow pop up plug mechanism
    By jmackay85 in forum Plumbing Forum
    Last Post: 18-04-2013, 07:46 PM
  4. Choice of Flushing Mechanism
    By BazzerLondon in forum Sanitary Ware
    Last Post: 04-07-2010, 07:45 PM
