Old 29-11-2007   #1 (permalink)
neco
View neco's Photo Album
Default : How can you increase the Water Pressure ?
neco is offline   Reply With Quote
Old 29-11-2007   #2 (permalink)
uug197h
View uug197h's Photo Album
Default Re: : How can you increase the Water Pressure ?
your water pressure can be reduced but not increased, you can get a better flow by using 22mm pipe then reducing to 15 mm just before the taps
Old 30-11-2007   #3 (permalink)
ramya
View ramya's Photo Album
Often the problem will appear to be a pressure issue when it comes to volume or flow issue. A restriction in a line or just having a long line or under sized line could be the problem. There are many considerations; do you have enough pressure at your mains? Do you have an old furred up pipe work, perhaps lead or galv? Is your main stop open fully?
If you install a pressure gauge, you can check pressure. It should be above about 35 PSI. 35 PSI would be on the low side, but should be ok. Look at the http://www.milwaukeeplumbers123.com then look at it when the water is on full in the bathtub. If the pressure is ok until you turn on the water than it is a flow problem.
ramya is offline   Reply With Quote
Old 01-12-2007   #4 (permalink)
nyless
View nyless's Photo Album
One way to over come this is to install a pressure tank and check valve. The tank will give you the flow and the check valve will keep the flow going only into the tank or house. The in-coming flow will feed your tank and house as the water is used, so the tank should last for a long time before you see a loss of pressure. I have had good results with this set up. One last thing to check is for clogged aerators at the sinks and showerheads.
life isn't about waiting for the rain to pass:
it's about learning to dance in the rain.
nyless is offline   Reply With Quote
Old 03-06-2008   #5 (permalink)
greenday
View greenday's Photo Album
simple jobs first! make sure your stop cock is fully open. some systems installed incorrectly can cause noise and vibration, this is sometimes solved by reducing the flow of water via the stop cock. Try it and see! let me know.
greenday is offline   Reply With Quote
Old 04-06-2008   #6 (permalink)
Phil
View Phil's Photo Album
I know this wont answer the question but whenever I turn off a stopcock I count the number of turns and put it back exactly how I left it, the same with lockshield valves.
Phil is offline   Reply With Quote
Old 05-06-2008   #7 (permalink)
MarkB
View MarkB's Photo Album
Quote:
Neco,
What kind of system is it?
If it's already an unvented system or a thermal store then as has already been said you can't increase it. However, if it's a vented gravity system then you could upgrade it to an unvented or thermal store.
Mark
MarkB is offline   Reply With Quote
Old 06-06-2008   #8 (permalink)
Alanka
View Alanka's Photo Album
Use a pump.
Raise the storage tank level.
If it's low pressure hot water supplying a shower, use a venturi shower to boost the hw pressure/flow.
Cheers,
Big Al
Hot water fine pressure on heating building up David Want Central Heating Forum 1 06-10-2008 09:16 PM
Low water pressure for garden irrigation system mgraham Plumbing Forum 1 01-09-2008 12:48 PM
Hot water pressure - kitchen tap Bob Plumbing Forum 9 27-07-2008 11:20 PM
Loast hot water pressure Tosh Valves & Taps 3 22-07-2008 08:19 AM
