Page 1 of 4 1234 LastLast
Results 1 to 12 of 39
Plumbing & Plumbers Forum - Radiator Valve Sizes
Like Tree12Likes
Discuss Radiator Valve Sizes at UK Plumbers Forums; I tried to adjust the lockshield valve on my 15 year kitchen radiator and it started leaking. I therefore decided to replace it and thought this would be a straightforward ...
    Jan 2017
    11
    Default Radiator Valve Sizes
    I tried to adjust the lockshield valve on my 15 year kitchen radiator and it started leaking. I therefore decided to replace it and thought this would be a straightforward job. Unfortunately, the thread on the old valve appeared to be about 1" in diameter as was the nut on the radiator outlet.
    I went round to our local Graham Plumbing merchant and nobody there seemed to have ever come across a radiator with this size valve before. If I can't find a suitable valve or converter then this radiator will need to be replaced which seems a little bit drastic.
    Is the world going mad or is there a plumber out there who can offer me a solution?
    Plumbers Arms member rocketmanbkk's Avatar
    Langley, Berkshire
    4,098
    Default Re: Radiator Valve Sizes
    Post a pic of the valve. You might need. Valve & rad tail
    A pic will tell a thousand words
    Chalked's Avatar
    3,922
    Most new radiator valves are 1/2 inch, thread/ 15mm copper. You have a union type radiator valve. These are 1". The trouble is that there are lots of different types of these, so you are better off removing the tail ( the bit in the rad) and use the tail that comes with a new valve.
    rocketmanbkk likes this.
    Jan 2017
    Hi 3/4" on domestic is normally the biggest on a rad this age
    Commercial valves can be bigger for black iron fitting
    try using brass bushes or reducers to get to the correct size if there is enough room on the pipework
    use a good seal prob PTFE as bushes and reducers are often not tapered
    May 2010
    5,156
    Welcome AWJD to the forum's......any chance of a picture of the valve as it could be helpful with your enquiry.....regards Turnpin
    9,983
    Quote Originally Posted by COHIBA1207 View Post
    It's a lockshield Union mate
    rpm
    rpm is online now
    Member rpm's Avatar
    Wherever I lay my hat
    7,958
    Welcome to the forum.
    Bit of an over kill isn`t? Bushes and fittings can be parallel or tapered threads and easy for an amateur to get wrong.
    Jan 2017
    11
    I attempted to load a picture of the valve via the 'Image' icon but, after selecting the file, the update file(s) link didn't work. Could someone please explain what is going wrong?
    Jan 2017
    11
    Not sure the upload of the picture worked but if it did it shows the Lockshield valve with 1" thread. .
  10. The Following User Says Thank You to AWJD For This Useful Post:
    9,983
    Stnd drain off lockshield, if it's leaking where the ptfe tape is wants some compound on it
    Dec 2016
    Bradwell , near Great yarmouth ,norfolk
    123
    Take the picture on your phone to screwfix with you they sell them fitted one today it's a standard valve bud
  13. #12
    rpm
    rpm is online now
    Member rpm's Avatar
    7,958
    Isn`t it an O-ring to make the seal?
  1. Radiator sizing (again) - are these sizes reasonable
    By imrreh in forum Central Heating Forum
    Last Post: 26-08-2016, 06:02 PM
  2. Unusual Radiator Sizes
    By Murdoch in forum Central Heating Forum
    Last Post: 21-06-2013, 01:07 PM
  3. Radiator Sizes
    By baby chicken in forum Central Heating Forum
    Last Post: 07-12-2011, 09:29 AM
