Page 4 of 4 FirstFirst 1234
Results 37 to 39 of 39
Plumbing & Plumbers Forum - Radiator Valve Sizes
Like Tree12Likes
Discuss Radiator Valve Sizes at UK Plumbers Forums; Originally Posted by steveb it is called 3/4" not 1" that's why I was referring to the diameter of the tread which was 1". And yes, this is also referred ...
  1. #37
    Jan 2017
    11
    Default Re: Radiator Valve Sizes
    Quote Originally Posted by steveb View Post
    I was referring to the diameter of the tread which was 1". And yes, this is also referred to as a 3/4" BSP thread- and the plumbing merchants still didn't stock it!
  2. #38
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,840
    Quote Originally Posted by AWJD View Post
    I bought part 36552 from Screwfix. As said, I took the original valve into the 2 x plumbing merchants and neither had a size that matched. I'm going back to Screwfix tomorrow to get another valve for the other end of the radiator without the drain.
    Glad you got it sorted in the end however left wondering exactly what words you used ie did you say 1" for the radiator in which case I can understand the response you got.
  3. #39
    Jan 2017
    11
    I needed to sort out the issues with my radiator valves because this summer I will need to get all the valves changed (TRVs included this time) and didn't want any nasty surprises in terms unavailable parts. My final understanding is the following:
    1. All my old radiators and modern radiators use tails which all have a 1/2 BSP male tapered threads going into the radiator.
    2. Therefore, since replacement valves come with a tail, it should be possible, worst case, simply to replace the old tails (and valves) with the new tails (and valves).
    3. The old standard for valves was to use a 3/4 BSP union connection ('O' ring or fibre washer seal) to the radiator tail.
    4. The new standard for valves is to use a 15mm compression connector to the radiator tail.
    5. Many plumber merchants don't appear to stock radiator valves with union connections any more - fortunately, other outlets, such as Screwfix do stock them still.
    This has been a bit of a steep learning curve for me, not helped by not knowing what correct terminology to use at times! However, I got there in the end!
  1. Radiator sizing (again) - are these sizes reasonable
    By imrreh in forum Central Heating Forum
    Last Post: 26-08-2016, 06:02 PM
  2. Unusual Radiator Sizes
    By Murdoch in forum Central Heating Forum
    Last Post: 21-06-2013, 01:07 PM
  3. Radiator Sizes
    By baby chicken in forum Central Heating Forum
    Last Post: 07-12-2011, 09:29 AM
