Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 39
Plumbing & Plumbers Forum - Radiator Valve Sizes
Like Tree12Likes
Discuss Radiator Valve Sizes at UK Plumbers Forums; Originally Posted by rpm Isn`t it an O-ring to make the seal? No mating surface like big gate valves...
  1. #13
    9,995
    Default Re: Radiator Valve Sizes
    Quote Originally Posted by rpm View Post
    rocketmanbkk likes this.
  2. #14
    Jan 2017
    11
    This valve has reached the end of its life and was leaking underneath where it's now covered in black RTV silicon. As said, the problem in replacing it is that it appears to have a 1" thread on the radiator outlet which must have been common when I fitted it 15 years ago. This size fitting no longer seems to be available unless someone knows better?
  3. #15
    9,995
    Quote Originally Posted by AWJD View Post
    We have told you it's a stnd lock shield drain off
    http://www.screwfix.com/p/chrome-ang...ails_container
    Chalked and rocketmanbkk like this.
  4. #16
    2,031
    No, taper
    http://www.screwfix.com/p/chrome-ang...rain-off/70408
  5. #17
    Somewhere in the South West
    110
    Its a common valve. We do know better and we are trying to tell you this
  6. #18
    rpm
    rpm is online now
    Member rpm's Avatar
    Wherever I lay my hat
    7,959
    When doing 6"- 18" gate valves there was a gasket, how do these seal then?
  7. #19
    9,995
    Just brass on brass mating surfaces
  8. #20
    rpm
    rpm is online now
    Member rpm's Avatar
    7,959
    Quote Originally Posted by snowhead View Post
    Thanks snowhead, understand the taper there, meant under the nut ie usually expect olive or O ring.
  9. #21
    rpm
    rpm is online now
    Member rpm's Avatar
    7,959
    Ok, got it. Little cross posting going on there.
  10. #22
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,921
    The Turtle Moves
  11. #23
    9,995
    Quote Originally Posted by steveb View Post
    That one is for 15mm think op has 10mm Pipework
    steveb likes this.
  12. #24
    Jan 2017
    11
    I have now been to both the main plumbing merchants in Abingdon (Grahams and Plumb Centre) and nobody in either had ever seen a Lockshield valve with drain with a 1" thread to the radiator. The guy in the Plumb Centre said he'd worked there for 25 years and never seen one even though my radiator is only 15 years old.
    How come I can then walk into Screwfix of all places and buy one over the counter as recommended by you guys on the forum? It seems to be a standard size for Screwfix but to nobody else in the industry?
  1. Radiator sizing (again) - are these sizes reasonable
    By imrreh in forum Central Heating Forum
    Last Post: 26-08-2016, 06:02 PM
  2. Unusual Radiator Sizes
    By Murdoch in forum Central Heating Forum
    Last Post: 21-06-2013, 01:07 PM
  3. Radiator Sizes
    By baby chicken in forum Central Heating Forum
    Last Post: 07-12-2011, 09:29 AM
