Plumbing & Plumbers Forum - icos ideal problem
icos ideal problem
Discuss icos ideal problem in the Plumbing Forum at Plumbers Forums; I have a icos ideal boiler in a new house plumbed with 10mm flexi hose, i have removed a radiator and capped the ends but now my boiler wont fire ...
    spander
    Unhappy icos ideal problem
    I have a icos ideal boiler in a new house plumbed with 10mm flexi hose, i have removed a radiator and capped the ends but now my boiler wont fire up and the pump/motor in the airing cupboard is getting really hot and making a noise, by doing this have i stopped the continual water flow or something ??
    Apr 2009
    216
    Default Re: icos ideal problem
    Pump will need bleeding.
    spander
    Many thanks, but sorry to sound dumb and due to the fact that there is a mass of valves and pipes connecting expansion tanks etc whereabouts would i find the bleed valve ??
    Apr 2009
    216
    On the pump (probably grundfos) you will see a large chrome disc with a slotted screw. Turn this anticlockwise with a large slotted screwdriver until a little water is released.This should start the pump circulating again. It is the bleed screw on the pump you are looking for!
    Hpoe this helps. Dont forget to re tighten once water is released.
    spander
    Thanks very much will try tomorrow as little one is asleep in the room at the mo, will update you tomorrow.
    Blackcatgas's Avatar
    Oct 2009
    Nottingham
    1,672
    These boilers hate air, we could spend up to an hour trying to get them to fire up.
    spander
    Expansion tank is showing 0 bar pressure, jusy got back from work and researching how to re-pressureise, will attempt that tomorrow....
    re-pressurized using filling loop and alls well.
  1. any ideal icos experts out there
    By P4ULT in forum Central Heating Forum
    Last Post: 16-03-2011, 03:59 PM
  2. HELP! Ideal mini C-24 hot water problem
    By alexz in forum Central Heating Forum
    Last Post: 06-02-2010, 03:33 PM
  3. Ideal mini 24 problem?
    By no1keeper in forum Central Heating Forum
    Last Post: 08-01-2010, 06:59 PM
  4. Ideal Isar boiler problem
    By Chappers in forum Central Heating Forum
    Last Post: 08-01-2010, 06:40 PM
  5. Ideal Elan 2 boiler problem
    By eamdp03 in forum Central Heating Forum
    Last Post: 19-12-2009, 09:22 AM
icos ideal boiler problems
icos boiler filling loop
tightening grundfos chrome bleed screw
ideal isar bleed nipple
