Plumbing & Plumbers Forum - air lock in hot water system
Discuss air lock in hot water system at UK Plumbers Forums; With your help I have fixed my thermal store central heating system. However I seem to have air lock in hot water. All taps except bathroom give hot water. Bathroom ...
    plumrob
    Default air lock in hot water system
    With your help I have fixed my thermal store central heating system. However I seem to have air lock in hot water. All taps except bathroom give hot water. Bathroom is a dribble. have tried fixing washing machine hose to cold and hot fill to blast airlock. No success. Any other options?
    May 2009
    7,301
    Default Re: air lock in hot water system
    Well your hot water should be main pressure through thermol store so should not have air lock,is it just one tap that is not working,if so could be tap or a bit of rubbish stuck in both taps
    However as you was working on system last week,check no valve is closed to bathroom or not opened correctly
    imho
    plumrob
    Hello again.
    yes it is only bathroom hot tap. All other work ok. Bathroom tap becomes an old man's dribble accompanied by knocking noise. have tried the mains cold to hot system using the washing machine pipe but no success.
    May 2009
    7,301
    Well if tap knocking and dribble, probably tap head faulty,do not know what taps you have maybe ` 'adapt a tap' or 'tap revivers' or 'standard tap' heads will fit or isolate water supply and remove head and see if jumper can be fixed
    Jan 2008
    North Yorkshire
    4,777
    Washer is probably stuck inside the tap.
  1. hello
    By uug197h in forum New Member Introductions
    Last Post: 15-10-2015, 08:19 AM
  2. CH system losing water
    By osh in forum Central Heating Forum
    Last Post: 24-10-2012, 10:47 AM
  3. Replies: 9
    Last Post: 28-08-2012, 03:32 PM
  4. Replies: 16
    Last Post: 23-08-2012, 08:24 PM
  5. Air in hot water system
    By clan184 in forum Plumbing Forum
    Last Post: 17-05-2012, 03:02 PM
  6. Air lock in hot water
    By longcg in forum Plumbing Forum
    Last Post: 08-12-2011, 12:07 PM
  7. Help ASAP please- possible air lock in hot water system?
    By Jimbob82 in forum Plumbing Forum
    Last Post: 07-08-2011, 06:47 PM
  8. "Lock Out", Hot Water...
    By Starship1 in forum Central Heating Forum
    Last Post: 09-05-2011, 11:08 AM
  9. Water System Help!?!
    By rsteele1113 in forum Plumbing Forum
    Last Post: 09-04-2011, 11:37 PM
  10. hot water system
    By Chrissy in forum Plumbing Forum
    Last Post: 17-08-2010, 03:43 PM
hot water tap in bath dribbling
