Page 4 of 7 FirstFirst 1234567 LastLast
Results 37 to 48 of 73
Plumbing & Plumbers Forum - Vibration in floor...boiler/water heater?
Like Tree7Likes
Discuss Vibration in floor...boiler/water heater? at UK Plumbers Forums; Sorry for poor spacing above, I'm having to type out my response on word and then copy and paste here now, for some reason my keyboard doesn't work well on ...
  1. #37
    Aug 2016
    47
    Default Re: Vibration in floor...boiler/water heater?
    Sorry for poor spacing above, I'm having to type out my response on word and then copy and paste here now, for some reason my keyboard doesn't work well on this site!
  2. #38
    Aug 2016
    47
    I don't know if anything in this thread makes sense to anyone...(in relation to my issue). Thanks.
    http://www.***********/diy/threads/v...-house.413703/
  3. #39
    rpm
    rpm is online now
    Member rpm's Avatar
    Wherever I lay my hat
    7,835
    Coming up as a blank page.
  4. The Following User Says Thank You to rpm For This Useful Post:
  5. #40
    Aug 2016
    47
    Sorry, it doesn't seem to want to be shared...will try again
  6. #41
    9,660
    Quote Originally Posted by rpm View Post
    Add diynot.co.uk where the ***** are
  7. The Following User Says Thank You to ShaunCorbs For This Useful Post:
  8. #42
    Aug 2016
    47
    Quote Originally Posted by Rachiex View Post
    Ok an update. What can you gather from this so far?
    There are only 3 possible neighbours in my block, one below me, one next to me on the first floor and one below him.
    A lot of the time when I'm woken in the early hours both my next door (on my level) and the person beneath him are already up and getting ready for work (lights are on). The vibration often starts around or before this time. (it also sometimes goes like the clappers in the middle of the night, between midnight and four am sometimes continuously and it's like a mini earthquake in my flat).
    The person beneath me has been kind enough to check all appliances with me and none of them caused a vibration, BUT we haven't checked whether the night water heater is doing it because we couldn't check that during the day (apparently it comes on by itself and she doesn't touch it, even if going away).
    Here's something. A local plumber told me to watch two pipes on the front of my building. There was a long one that comes out of the wall of my flat and a short one, comes out of the wall of the downstairs flat. He said if either of them start dripping water when the vibration is taking place, it's a sign that someone's boiler is overheating.
    Well a couple of times in the middle of the night when there is a mini earthquake going on, I've gone out and the shorter pipe is leaking water, regularly dripping.
    Now in theory that would be coming from my downstairs neighbour's home, BUT I'm actually more of the belief that the vibration is coming from the flat next door, because it always seems to happen when that person is in or comes home and not otherwise.
    Before I call anyone out (and I'm away most of this week and next on work trips), any thoughts on this one? Could that short pipe, even though it seems to be coming out of the downstairs flat, be coming from my next door neighbour on my first floor level? What would it's leaking point to?
    This is starting to freak me out a bit because it really is intense at times (the last two nights in fact, perhaps due to drop in temperature) but all three neighbours say they don't feel or hear anything and I can't knock any of them up in the middle of the night yet, until I'm clearer on where it's coming from. Surely at some point something will give, my lounge floor and bedroom is vibrating intensely when it happens. I have a feeling my next door neighbour knows what it is as he seems to have avoided conversation about it with me. He also mentioned having had a valve replaced on his water heater and said he wished he could afford a new water heater. But of course it could be me just thinking that it's coming from there.
    On another note I haven't a clue what people are talking about when they mention the ball cock in a cistern, how could that, going below a certain level cause such intense (mini earthquake type) vibrations across my flat?
    Thanks for your time everyone.
    Anyone have any idea about this above? I'm just wondering whether to call a plumber out next week or give up and move. (the crucial thing being whether it's worth having a plumber come out if the vibration is not actually happening and/or even if it was happening, what can they possibly know from it alone with no other clues) Thanks.
  9. #43
    Apr 2013
    Blackpool
    63
    I am not a plumber so my suggestion is not a plumbing solution. While it would be great to get to the bottom of the problem and fix it, maybe a quicker easer solution is to reduce it's impact on you. What I mean is if it's the vibration that is waking you up then maybe stop the vibrations going to the bed. You can get anti vibration mounts, not intended for beds but they might work. Have a google for anti vibration mounts and see what you can find that can go between the bed and the floor.
    Hope that gives you some ideas that you could try without bothering the neighbours.
    Fingers crossed you can find a solution that gives you a good night sleep.
  10. The Following User Says Thank You to john999uk For This Useful Post:
  11. #44
    Aug 2016
    47
    Quote Originally Posted by john999uk View Post
    Thanks I appreciate the suggestion, I have tried virtually everything sadly and have been given the same advice by an audio specialist (he did say that some vibrations permeate everything though), sadly this vibration permeates everything..so now it's find the source or move (and I'm so exhausted moving is not appealing either at the moment). Appreciate the thought and I will have one last search though, thanks.
  12. #45
    Aug 2016
    47
    The reason I am posting again is I'm trying to arrive at a decision. I don't want to leave this in limbo for much longer.
    I'm wondering if the reason there are no responses to my latest post is because it is a very complicated issue and difficult to find the source? If that's the case, please feel free to tell me what you're all thinking because I need this to stop one way or another, either by finding the source (and to me the evidence suggests downstair's water heater overheating, or next door neighbour's water heater) OR by making plans to move. I've been getting four hour's sleep a night for a year now and I have to stop the problem one way or the other.
  13. #46
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,121
    Hello again.
    Do you know if the neighbours have unvented hot water cylinders ?
    If it's a pressure relief valve operating, they will open and shut rapidly. This gives a fast thumping that could possibly cause vibrations to travel depending on where the tank and pipework is in relation to your floor.
  14. The Following User Says Thank You to Last Plumber For This Useful Post:
  15. #47
    Aug 2016
    47
    Quote Originally Posted by Last Plumber View Post
    Hello again.
    Thanks Last Plumber
    I've just looked it upand yes, I'm thinking that all the flats would have unvented as I'veheard no one talk here about a water tank in any loft, etc.
    The neighbour who toldme his boiler was noisy, later told me he had a valve replaced and hedoes sometimes wonder whether it'll 'hold' but when I asked him if hefelt any vibration coming from it he said no and has avoided myrequests for switching things on in his flat to see if anythingcauses a vibration.
    That said, I know thataround the time this all started last year, my downstairs neighbourhad a new water heater put in, but it was a couple of months afterthat that I noticed a problem. The downstairs neighbour also reportsthat all pipes from that water heater go down into the ground, not uptowards my flat.
    I have 3 theories onthe go currently:
    1. It's the neighbour next door's water heater/boiler, who said it was noisy and really needed replacing
    2. It's the new water heater that was installed downstairs last year
    3. It's the neighbour next door's subwoofer (or whatever these things are)
    Logic tells me it'sunlikely to be number 3 because it often happens when that neighbouris in bed and he gets up incredibly early for work, so unlikely to beup all night with subwoofer on, etc.
    All the rest of theevidence points to number 1, from what he said and the fact that hehad a valve replaced....but also to number 2, because there's anoverflow copper pipe on the outside of downstairs' flat that issometimes rhythmically dripping water in the early hours when thevibration is going like the clappers, lol.
    I think I'm going tosee what a plumber thinks as soon as I can and then, depending onwhat he works out, ask the landlady to speak to all adjoiningneighbours, failing that, plan to move.
  16. #48
    Aug 2016
    47
    If it were my neighbour, could he live with that sound in his own flat, in the middle of the night? I suppose if it's too expensive to replace then perhaps so.
    I've learned one thing from all this, sound isn't as bad as vibration. You can learn to shut out sound, but not vibration.
  1. Replies: 4
    Last Post: 03-07-2012, 08:53 PM
  2. Hot Water Heater Boiler
    By Casterina in forum Central Heating Forum
    Last Post: 17-09-2011, 09:39 AM
  3. water heater or boiler ?
    By stevetheplumber in forum Gas Safe Register Forum - Public Forum
    Last Post: 11-02-2010, 07:46 PM
