Old 26-07-2008   #1 (permalink)
didydave
View didydave's Photo Album
Cool Pulsating Shower Pump
I have just replaced a shower in a clients house. The shower i took out was a simple leaver shower with hot and cold water coming in at the sides and mixed water coming out of the the third pipe. the one i have put back in is exactly the same stype and infact i used a lot of the original fittings to make the connections. All the fittings are consealed behind the tiles with a chrome leaver tap and the hose only showing. The pipe work behind the tiles were not changed and neither was the elctric pump.
The problem i the client is now having is that when the shower head is over a certain height the pump pulsates. Is this a faulty shower pump or something that i have done? the only that was fitted that was not according to instrcutions was that the shower mixer was fitted upside down, as was the original one, so that the hot feed was on the right not the left.
If you have any ideas please let me know.
David
didydave is offline   Reply With Quote
Old 27-07-2008   #2 (permalink)
NickH
View NickH's Photo Album
Default Re: Pulsating Shower Pump
Pulsates how ? does it switch on and off or surges ?
NickH is offline   Reply With Quote
Old 27-07-2008   #3 (permalink)
didydave
it switches itself on an off very quickly, pulsing
Old 27-07-2008   #4 (permalink)
sagsy
View sagsy's Photo Album
is the pump a salamander pump if if it you will need to contactact salamander and get them to send yiu a backflow valve that is fitted on hot water outlet on pump.
sagsy is offline   Reply With Quote
Old 28-07-2008   #5 (permalink)
didydave
No It's not a salamanader pump in fact i have no idea who the pump is made by. does it matter if it's salamander or not? I will check with my local suppliers to see if i can get a backflow valve for it.
Didydave
Old 28-07-2008   #6 (permalink)
sagsy
The reason I said this was I had the same problem when I fiited the salamander pump. I contacted them and they told me to fit the backflow valve on the hot outlet, they even supplied the valve FOC. you could also just fit a double check valve on the hot outlet pipe going from pump to shower.
Old 28-07-2008   #7 (permalink)
didydave
I have contacted Salamandar, thru their website and await a conversation however if a double check valve solved your problem sagsy then it's worth a try. certainly better than ripping out the new shower and old pump.
cheers.
Old 28-07-2008   #8 (permalink)
ajs heating
Posts: n/a
sounds like the pump is on the border line of a positive/negative situation.
if your not getting the correct flow per min gravity it will pulse or not start at all.
i would of fitted the mixer the right way round and changed the hot/cold on the outlets from the pump.
Old 28-07-2008   #9 (permalink)
Chris R
View Chris R's Photo Album
Re contacting Salamander - I have tried a few times to contact them via the website and they never reply - it is best to give them a ring. I have the smae problem - Salamander called it 'ram-rodding' and have sent my customer a free valve to sort it
Chris R is offline   Reply With Quote
Old 29-07-2008   #10 (permalink)
didydave
I wish i had turned the shower round now but sadly that is no longer an option as the whole thing is now tiled however if this is rma rodding with a check valve stop or make the problem worse? Oh and the old shower was fitted upside down with out any problems so why would the new one, which is exactly the same design, have this problem?
Thanks to all who have replied to my plee's
Separate pump in addition to the one included in the condensing boiler? hughs Central Heating Forum 7 1 Week Ago 06:05 PM
Shower hot water problem deaddraw Plumbing Forum 5 3 Weeks Ago 10:53 PM
Poor flow from shower head!! dsinclair999 Showers and Wetrooms 1 05-10-2008 11:42 PM
showerforce easiboost shower pump problem wallofbeans Showers and Wetrooms 0 21-09-2008 07:02 PM
shower pump kenneth_cohan Plumbing Forum 1 04-08-2008 06:29 PM
