Results 1 to 11 of 11
Plumbing & Plumbers Forum - 90 degree bend in polybutylene pipe within elbow
Discuss 90 degree bend in polybutylene pipe within elbow in the Plumbing Forum at Plumbers Forums; Hi all, I was just wondering if anyone knows of a way to form a 90 degree bend in a polybutylene pipe without using an elbow connector. The pipe runs ...
    Aug 2009
    25
    Question 90 degree bend in polybutylene pipe within elbow
    Hi all,
    The pipe runs in a floor void and will be hard to access once installed, so I wanted to eliminate a potential leak source if at all possible.
    I vaguely remember a metal part that wrapped itself around the pipe to form a bend but maybe I'm mistaken...
    All help and advice gratefully received.
    Tony.
    trying
    Default Re: 90 degree bend in polybutylene pipe within elbow
    personally i would use a cement welded joint if done correctly no problem, can u not create an access panel for future service.
    Aug 2009
    584
    Can you solvent weld polybutylene pipe ??
    The original poster did not say what size the pipe was nor if it was for water services, central heating, or a waste pipe
    Aug 2009
    25
    Quote Originally Posted by trying View Post
    Thanks for that reply trying. I didn't mention that the pipe in question is a 15mm water supply pipe. Is it still possible to weld the joint?
    No, it's not really possible to create an access panel. It runs behind a short run of floor standing built-in cabinets. It might be possible to access it by removing the plinth, but it might still be difficult to reach it.
    Tony.
    Plumbers Arms member johnmcginty's Avatar
    Jan 2008
    leeds
    718
    You can either get a cold forming bend which will give a tighter bend than normal or heat it up with friction or hot air gun and bend the pipe.
    SPEEDFIT 22MM COLD FORMING BEND 22CFB John Guest Speedfit H-K BRANDS
    Aug 2009
    584
    In France you can get "shoes" that the pipe fits in for a bend this stops the pipe from "throating" or collapsing at a later date, don't know about the UK
    Aug 2009
    25
    Quote Originally Posted by johnmcginty View Post
    This is exactly what I need. I knew I'd seen these somewhere before but wasn't sure they were for 15mm pipes.
    Thanks again.
    Tony.
    Jan 2008
    leeds
    718
    No worries the link is just en example photo, you can pick them up from b and q too.
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,084
    or toolstation
    ¿ʞɹoʍ sɐƃ
    Jan 2008
    leeds
    718
    Quote Originally Posted by REDSAW34 View Post
    or toolstation
    I think I get around 95% of my gear from toolstation, I just like the fact that you can see all the prices, good call.
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,084
    me too, its like a info catalouge where you can work out best to solve problem, especially in the pan connectors.
    cheap as chips too ie check out 25 elbows 15mm skrufix
    ¿ʞɹoʍ sɐƃ
  1. brass pipe ,where to get some and how to bend it.
    By that bloke. in forum Plumbing Forum
    Last Post: 05-03-2013, 12:16 AM
  2. pipe bending
    By pnhsolutions in forum Plumbing Forum
    Last Post: 08-02-2013, 06:44 PM
  3. Shower Pump & Pipe Diameter Question
    By spcdust in forum Bathrooms, Showers and Wetrooms
    Last Post: 27-08-2009, 01:13 PM
  4. 180º bend in Soil pipe
    By cheapskate in forum Plumbing Forum
    Last Post: 11-08-2009, 07:54 PM
  5. Pipe CHASING electric shower
    By bureaucrazy in forum Bathrooms, Showers and Wetrooms
    Last Post: 08-04-2009, 10:06 PM
bending polybutylene pipe
how to bend polybutylene
how to bend polybutylene pipe
polybutylene pipework
pb pipe bend support
how do you bend Polybutylene
polybutylene bending
