Results 1 to 15 of 15
Plumbing & Plumbers Forum - Hot water recirculation
Discuss Hot water recirculation in the Plumbing Forum at Plumbers Forums; I'm interested to know if this is worthwhile as I have yet to complete my plumbing system. All the web info seems to be from USA. Seems to make sense ...-
24-03-2010 #1New to Plumbing Forum
- Jul 2009
- derby
- 15
I'm interested to know if this is worthwhile as I have yet to complete my plumbing system. All the web info seems to be from USA. Seems to make sense if hot water immediately available, then less water down the drain. But maybe the cost of circulation pump electricity is a drawback.
I'd like to know what pump would be suitable, and what pipe size for the return loop.
24-03-2010 #2Plumbing Forum Contributor
- Feb 2010
- 75
24-03-2010 #3Plumbers Arms member
- Oct 2008
- oxfordshire
- 1,872
- 477
- Thanked 183 Times in 142 Posts
Re: Hot water recirculation
Also you do not necessarily want the secondary return pump to be running 24 hours a day so you can install a timer on it so it only works at peak times, in the long term, this will save a lot of heat loss from the cylinder, and save energy.
if its not dangerous Im not doing it
24-03-2010 #4Plumbing Forum Contributor
- Feb 2010
- 75
24-03-2010 #5Plumbers Arms member
- Oct 2008
- oxfordshire
- 1,872
- 477
Nice one I didnt know that, good to learn something new each day, Cheers
24-03-2010 #6Plumbers Arms member
- Oct 2009
- Nottingham
- 1,672
- 57
- Thanked 132 Times in 121 Posts
It also has to be a bronze pump, twice the price of a normal central heating pump, a normal iron heating pump will rust solid pretty soon with fresh hot water running through it.
secondary pumps are normaly painted yellow.
Lagging the pipes around the circuit is also good practice.
25-03-2010 #7Plumbing Forum Contributor
- Jan 2010
- Worcester
- 97
- Thanked 3 Times in 3 Posts
The rule of thumb for a secondary return is a distance of 14m from the cylinder. This is based on getting hot water at the tap within 30 seconds.
If you do have one then generally 15mm is fine as long as its not a very large property (5 bathroom type). Make sure you insulate all of the hot and secondary return pipework.
As said in other posts the Grundfoss comfort range of pumps are good and you can get them with both inbuilt time clock and thermostat.
25-03-2010 #8New to Plumbing Forum
- Jul 2009
- derby
- 15
Many thanks guys, that was most helpful
23-08-2010 #9New to Plumbing Forum
- Aug 2010
can anybody tell me whether i could use Plastic pipe for a DHW Secondary loop. I am thinking of isntalling such a loop, in our house. (we have 3 ensuites, a main bathroom, currectly fed by two HW cylinders). I was think of using plastic pipe, for ease of installation and thermal effeciency. If i used a p100 MDPE pipe, i could weld the joints.
Any views anybody
23-08-2010 #10Moderator
- Jul 2009
- Staffordshire
- 2,547
- 41
- Thanked 191 Times in 162 Posts
personally i would do it in copper and lag it properly
too much plastic is not a good sign in my bookRegards
Tom
23-08-2010 #11New to Plumbing Forum
- Aug 2010
Thanks Tom, any reason for avoiding Plastic. The problem i have with Copper is that i would need to put in a lot of bends and access will be difficult to do that, whereas with plastic, i could thread the pipe through the awkward bits.
23-08-2010 #12Plumbing Forum Contributor
- Feb 2010
- 75
23-08-2010 #13UK Plumbersforums Trusted Advisor.
- Jun 2010
- Northern Ireland
- 4,654
- 64
- Thanked 432 Times in 419 Posts
Plastic pipe is fine to use if that suits your instalation
23-08-2010 #14Plumbers Arms member
- blackpool
- 2,139
- 4
- Thanked 10 Times in 8 Posts
also the grundfoss do an a rated secondary return pump. very clever, self regulating. instead of the normal 55watt power consumption these decide on the power needed and sort it out. not one of the ten or so ive installed use over 7watts, with the best one using only 3watts ( was as a cylinder destrat tho )
Shaun, GS 233006, Engineer 2485197
24-08-2010 #15Top Plumbing Forum Contributor
- Jun 2010
- Cumberland
- 975
- 11
- Thanked 86 Times in 82 Posts
A general rule of thumb for hot water circ is return pipe 2 sizes smaller than flow pipe. Or you can calculate heat losses and size it .
Plastic pipe is not normally recommended for hot water circulation , however if it is domestic with a time switch the manufacturers say it should be OK . This comes from the fact that hospitals/hotels etc run it 24/7. Plenty of lagging !
central heating and hot water not working again..
By mad_cereal_love in forum Central Heating ForumReplies: 3Last Post: 02-02-2010, 08:47 PM -
Hot Water only luke warm
By baglartimus in forum Plumbing ForumReplies: 1Last Post: 07-01-2010, 11:47 AM -
By RolandK in forum Plumbing ForumReplies: 10Last Post: 02-01-2010, 07:50 AM -
Bungalow with requirement for instant hot water and more water pressure in bathrooms
By David Salter in forum Bathrooms, Showers and WetroomsReplies: 3Last Post: 06-10-2009, 11:56 PM -
Brown hot water
By Leeky in forum Central Heating ForumReplies: 10Last Post: 14-12-2008, 02:50 PM
5" flue, what core size?
3 Minutes Ago in Plumbing Forum
