Results 1 to 9 of 9
Plumbing & Plumbers Forum - Outside Tap
Outside Tap
Discuss Outside Tap in the Plumbing Forum at Plumbers Forums; I'm fitting an outside tap, the pipe i'm cutting into is painted, would i need to replace part of the pipe put a compression fitting onto the pianted pipe so ...-
22-03-2010 #1New to Plumbing Forum
- Jan 2010
- 11
Outside Tap
I'm fitting an outside tap, the pipe i'm cutting into is painted, would i need to replace part of the pipe put a compression fitting onto the pianted pipe so I can solder the fittings, or is there an easier way?
22-03-2010 #2UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
Re: Outside Tap
You need to scrape the paint off whatever technique you use, be it compression or solder. Use a green pan scrub to get the little bits off once you have had a good scrape.
BTW have you remembered to fit a double check valve between the stopcock and the outside tap (legal requirement)?
22-03-2010 #3New to Plumbing Forum
- Jan 2010
- 11
Re: Outside Tap
Thanks for that, and yes i've got a bib tap with double check valve already in it.
Cheers again
Dan
22-03-2010 #4Plumbers Arms member
- Jan 2008
- leeds
- 718
- 16
- Thanked 13 Times in 13 Posts
Re: Outside Tap
Most outside taps come with double check valves nowadays
22-03-2010 #5UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
Re: Outside Tap
You shouldn't use a bibtap with integral check valve - these are for retrofits only. The water regs state there should be an independent check valve inside the property.
Taps with check valves tend to fail in frost.
22-03-2010 #6Plumbers Arms member
- Oct 2009
- Nottingham
- 1,672
- 57
- Thanked 132 Times in 121 Posts
Re: Outside Tap
calefi ? do a combined double check valve and isolator.
22-03-2010 #7Plumbing Forum Contributor
- Oct 2009
- s/east
- 58
- 3
- Thanked 2 Times in 2 Posts
Re: Outside Tap
clean the paint of pipe
22-03-2010 #8UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
Re: Outside Tap
good scrape with a stanly knife to get paint of
22-03-2010 #9SUPER MODERATOR
- Jan 2009
- sherrif county
- 9,119
- 241
- Thanked 530 Times in 493 Posts
Re: Outside Tap
Easiest way is to spin your grips around on it.
¿ʞɹoʍ sɐƃ
Outside Tap come apart from pipe
By zee in forum Plumbing ForumReplies: 5Last Post: 28-06-2010, 05:31 PM -
Mixer shower tap problem
By Twee in forum Plumbing ForumReplies: 8Last Post: 24-02-2010, 08:43 AM -
Intermitant hot (ceramic) tap
By Elvis in forum Valves & TapsReplies: 3Last Post: 27-01-2010, 12:26 AM -
bath tap / shower tap
By sav in forum Valves & TapsReplies: 6Last Post: 04-10-2009, 03:05 PM -
Screaming cold tap
By antioch in forum Valves & TapsReplies: 7Last Post: 13-08-2009, 12:50 AM
price guides
44 Minutes Ago in Plumbing Forum
