Old 18-07-2008   #1 (permalink)
34mark@gmail.co
View 34mark@gmail.co's Photo Album
Default HELP! - WARM/HOT water coming from the COLD tap?
Hello
For no apparent reason the cold water has stop running from the Taps in the bathroom (both sink and bathtub) the loo won't refill either. The Cold tap in the kitchen sink is Fine with both pressure and cold temperature. The HOT water taps seem to be working fine from both Kitchen and Bathroom....
It seemed pretty weird how this problem happened, then I remember I turned all the radiators off and left 1 on about 3-4 days ago so I turned them all back ON...THEN the loo began to refill and when I tried the bathroom COLD tap....WARM/HOT water started running from them....???
I left them on for 15 minutes and now they have run dry again with nothing coming from the COLD taps in the Bathroom...
FINALLY - I have seperate hot & cold taps...And 30 minutes before the problem we had our annual service boiler inspection carried out by British gas!!
Thoughts anyone?
Very much appreciated.
Mark.
34mark@gmail.co is offline   Reply With Quote
Old 18-07-2008   #2 (permalink)
ajs heating
Posts: n/a
Default Re: HELP! - WARM/HOT water coming from the COLD tap?
what type of boiler system do you have ?
apart from that it don't make any sense as the radiators don't have nothing to do with the taps in any way.
Old 19-07-2008   #3 (permalink)
Alanka
View Alanka's Photo Album
Yes... Very weird!
Check your cold water tank (in loft?) if your system has one. Could be that it is empty due to a seized ball valve on the supply into the tank. This would dry up all taps that are supplied from this tank.
If your hot water cylinder (if you have one!) is also supplied from this tank, the hot water too should dry up -- but it hasn't -- so as I say, weird! Maybe the hot water will stop running but only after a delay (as the pipework empties)?
But do check the cw tank/cistern!
Cheers,
Big Al
Old 19-07-2008   #4 (permalink)
spindle
View spindle's Photo Album
Its possible you have got yourself an air blockage.
If you have had the heating on and the cold pipes where not full due to the block then its possible that heat from your hot water pipes has been able to heat up some of the water in your cold pipe as the usual volume is depleted. Even worse if the cold pipe is above the hot (which it should not be) that would heat the cold even more. Just a possible !
Suggest you check start at the top of the system and work your way down i.e cold water cistern in loft is full, ball cock free and outlet not blocked by anything horrible if you an't got a byelaw 30 kit on it.
Hope you resolve it.
Cheers ears Spindle.
spindle is offline   Reply With Quote
hot water from cold tap
hot water keeps cutting out on combi system obseen16 Plumbing Forum 2 21-08-2008 11:24 AM
water is coming up plug hole! claystiles Sanitary Ware 9 15-08-2008 08:28 PM
Cold water in shower nrmngrffn@aol.c Showers and Wetrooms 2 30-07-2008 10:30 PM
Hot water pressure - kitchen tap Bob Plumbing Forum 9 27-07-2008 11:20 PM
