Results 1 to 4 of 4
Plumbing & Plumbers Forum - Replacement waste fitting
Discuss Replacement waste fitting in the Plumbing Forum at Plumbers Forums; Hi There Attended a customer house to fix a leek from the stop tap going into some ancient type of water softening device. Whilst I was there customer asked me ...-
28-02-2010 #1Plumbers Arms member
- Jan 2010
- Lincolnshire and proud to be a yellow belly
- 502
- 23
- Thanked 24 Times in 20 Posts
Hi There
Attended a customer house to fix a leek from the stop tap going into some ancient type of water softening device. Whilst I was there customer asked me if I could replace the existing waste disposal unit. My question being, can i find a suitable waste fitting for existing basin as at present or is the existing fitting bespoke to the waste disposal/sink, see attached pics. Would welcoe your thoughts
Plum Bob
28-02-2010 #2Plumbers Arms member
- Jan 2010
- 502
- 23
Re: Replacement waste fitting
should have read "take out existing waste disposal and replace with normal sink trap"
01-03-2010 #3Plumbing Forum Contributor
- Jul 2009
- 51
- Thanked 3 Times in 3 Posts
Should be able to replace the waste disposal with a basket waste and then just add a normal trap on the bottom. They're usually one size i believe.
01-03-2010 #4UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
yes you need a basket strainer waste fitting
Sink to Waste Trap fitting?
By arthway in forum Plumbing ForumReplies: 5Last Post: 25-11-2009, 10:53 AM -
Kitchen Sink Waste
By ChipRivers in forum Plumbing ForumReplies: 18Last Post: 30-09-2009, 08:09 AM -
Don't carry any rubbish or risk a fine!
By emergencyman in forum General Off-Topic ChatReplies: 29Last Post: 07-07-2009, 06:52 PM -
Basin waste fitting - do I need a washer?
By bemused in forum Plumbing ForumReplies: 2Last Post: 23-01-2009, 09:54 AM -
HELP - bath waste problem
By pt44 in forum Plumbing ForumReplies: 12Last Post: 24-11-2008, 07:11 PM
what is it ?
8 Minutes Ago in General Off-Topic Chat
