Plumbing & Plumbers Forum - Guttering
Guttering
Discuss Guttering in the Plumbing Forum at Plumbers Forums; Hi all Ive got a customer who has a problem with some guttering. The guttering side of it isnt a problem, its just the downpipe that needs replacing. The downpipe ...-
23-02-2010 #1Plumbing Forum Contributor
- Jan 2009
- 45
Guttering
Hi all
Ive got a customer who has a problem with some guttering. The guttering side of it isnt a problem, its just the downpipe that needs replacing. The downpipe is cast iron, and is badly corroded at the bottom of the pipe where it goes into the ground. Im going to need to remove the whole pipe and replace it with plastic.
Whats the best way to do this? Is there a coupler that i can use from plastic to cast iron, and whats the best way to cut the cast iron?
At the bottom of the downpipe, it goes into the ground and is cemented into place. Am i going to need to remove the cement first to get a good fit?
cheers
Andy
23-02-2010 #2Plumbers Arms member
- Jan 2009
- Corsham, Wiltshire
- 819
- 8
- Thanked 22 Times in 21 Posts
Re: Guttering
I think you can get a rubber gaitor to go between the two, and I also think that it's cut with an angle grinder(beware cast is heavy and you will probably need a hand if removing it bit by bit).
23-02-2010 #3New to Plumbing Forum
- Apr 2009
- 19
Re: Guttering
When you cut it with the angle grinder, get a small bit of ply or bit of a box and slide it over the cut, cause if the cast break away in small fragments you might get it blocked and go from a easy job to a.........
23-02-2010 #4Plumbing Forum Contributor
- Dec 2009
- Newmains
- 71
Re: Guttering
Have a look at the shielded couplings on the Fernco website
Fernco Couplings, Flexible Couplings, Flexible Pipe Connectors, Fernco Fitting, Shielded Couplings, Fernco Donut, Pro-Flex Coupling, Large Diameter Couplings, Sewer, Drain, Waste, Plumbing Flexible Couplings, Plumbing Pipe Leak Repair | Fernco
Cheers
jack
23-02-2010 #5Plumbing Forum Contributor
- Jan 2009
- 45
Re: Guttering
sounds like it could be a bit more involved than i thought! I was planning to get a mate in to help out with it.
Any other advice?
cheers
andy
Guttering
By ste b in forum Plumbing ForumReplies: 0Last Post: 29-07-2009, 08:37 PM -
Guttering creepage?
By theoldboy in forum Plumbing ForumReplies: 2Last Post: 09-07-2009, 11:04 AM -
Guttering woes?
By theoldboy in forum Plumbing ForumReplies: 5Last Post: 10-11-2008, 11:09 AM
pricing up for little job
3 Minutes Ago in Plumbing Forum
