Results 1 to 10 of 10
Plumbing & Plumbers Forum - no hot water in bath or shower
Discuss no hot water in bath or shower in the Plumbing Forum at Plumbers Forums; hello very strange probelm. had bath last night which has just been fitted and have mixer shower also, perfectly fine both hot. wife then went in and no hot water, ...-
22-02-2010 #1kowalski181Guest
hello
very strange probelm. had bath last night which has just been fitted and have mixer shower also, perfectly fine both hot. wife then went in and no hot water, same on bathroom tap also
unfortunaely same thing this morngin have Worcester Combi Gas Boiler Greenstar 30cdi boiler fitted last year always worked fine on e setting for water, so changed to number 4 and hot water for sink came on but still nothing for shower and bath, anyone have any ideas?
22-02-2010 #2UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
Re: no hot water in bath or shower
I take it you are implying it is an intermittent fault?
If so I would suggest checking the flow switch on the Combi (Registered technicians job only)
22-02-2010 #3kowalski181Guest
ive bled a radiator this evenig that was ice cold and the presuure seems to have dropped to just above 1 on boiler after iswitched back on. the presuure increased a bit after i turned the pressure valve and quite a bit of water came out, but the water carried on coming for about 30 seconds so i decided to stop it and turn it in. i dont think i realised last night that the whole house appears to have been affected. it now seems to come on hot then go off then go back on.
its very strange
22-02-2010 #4Plumbing Forum Contributor
- Feb 2010
- 30
Hello - newbie here
I've got a similar problem.
I'm currently fitting a new bathroom in my mates house.
Basically - all i have done so far is turned the water off (Combi boiler) and installed a replacement mixer shower (dead easy job - straight onto the existing 15mm copper pipes)
Turned the water back on & the following day - my mate complained that the water in the bathroom was "just warm"
but, in the kitchen & the utilty room - the hot water in there seems to be a lot hotter.
Has the new shower done this ? (personally i don't think so - I think its just a coincidence)
anyone got any thoughts?
David
PS - new shower not operational yet - as i haven't tiled itLast edited by a4drk; 22-02-2010 at 08:48 PM.
22-02-2010 #5UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
You need a PRV on the cold to balance the pressures.
22-02-2010 #6Plumbing Forum Contributor
- Feb 2010
- 40
22-02-2010 #7Plumbing Forum Contributor
- Feb 2010
- 30
I take you mean to fit the pressure reducing valves on the shower? (hot & cold)
There are 2 x gate valves under the floor.
I haven't touched them.
So - question now is - Will the bath & basin temperatures be affected with the shower turned off ?
David
22-02-2010 #8Plumbing Forum Contributor
- Feb 2010
- 40
would not of thought so your mate my be winding you up
22-02-2010 #9kowalski181Guest
ive emptied the condensation bit from my boiler that had loads of bits of stuff in and clogged up with water and things have improved significantly, pressure is just above 1 though. will this be affecting the hot water inconsistencies throughout the house? central heating better than ever at bled radiator today
on the subject of increasing pressure on the worcester 30 si, when i turn the valve key there is quite a bit of water that comes out and it didnt stop after about half minute so i stopped it. is this normal?
cheers
28-02-2010 #10Plumbing Forum Contributor
- Feb 2010
- 30
I got to the bottom of my problem.
Basically - on the mixer - the Non Return Valve on the hot side was stuck open - and the cold water was feeding into the hot pipes. Sending a false signal back to the combi boiler. The gas man replaced thermistors on the combi - no difference. Then they took the heat exchanger out & cleaned it. It was then that they noticed cold water was coming out the hot taps in the kitchen when the hot was capped off at the boiler.
It was a complete pain - as i had to dig a big hole in the wall to remove the mixer valve (concreted in)
I cleaned it out, got it working - and for back up, i fitted a 15mm in-line compression non return valve under the floor boards.
all fine now.......
David
central heating and hot water not working again..
By mad_cereal_love in forum Central Heating ForumReplies: 3Last Post: 02-02-2010, 08:47 PM -
Hot Water only luke warm
By baglartimus in forum Plumbing ForumReplies: 1Last Post: 07-01-2010, 11:47 AM -
Hot water tap for bath has lost pressure
By Jim Cooper in forum Plumbing ForumReplies: 1Last Post: 29-12-2009, 05:57 PM -
Bungalow with requirement for instant hot water and more water pressure in bathrooms
By David Salter in forum Bathrooms, Showers and WetroomsReplies: 3Last Post: 06-10-2009, 11:56 PM -
Hot taps run cold - not the boiler, I reckon...
By plumb-line in forum Plumbing ForumReplies: 4Last Post: 30-03-2009, 09:21 AM
So what really goes on at these...
17 Minutes Ago in Plumbing Tools
