Results 1 to 11 of 11
Plumbing & Plumbers Forum - Copper pipe leak under sink
Discuss Copper pipe leak under sink in the Plumbing Forum at Plumbers Forums; Hi everyone Your help and expertise is very much appreciated, here's a picture to help. It's under my kitchen sink and the Copper pipes are coming from the kitchen tap. ...-
21-02-2010 #1ilovemyhomeGuest
Hi everyone
It's under my kitchen sink and the Copper pipes are coming from the kitchen tap. The leak is circled in red and it's coming from a pipe that doesn't look like it's in use anymore as the water seems to be diverted just above the shelf? It's just a drip but it fills up a pint cup over 6 hours, i don't want to mess around too much so i've just checked the red valve which is on as tight as it can be, is there anything i can do myself to stop the leak or do i need to call someone?
Thanks all!
21-02-2010 #2Plumbers Arms member
- May 2009
- 7,303
- 218
Re: Copper pipe leak under sink
Well if you go to a plumbers merchants tomorrow and ask for a washing machine valve cap with rubber inner washer they will give you a cap that just screws onto the red leaking valve,screw up tight and you should be ok
21-02-2010 #3UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
- Thanked 676 Times in 610 Posts
Alternatively if you have a pipe cutter and a push fit stop end, cut the pipe and put the stop end on it.
21-02-2010 #4Plumbing Forum Contributor
- Dec 2009
- Newmains
- 71
21-02-2010 #5UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
Wet change is much more exciting!!
I did that once on an outside tap fed by MDPE pipe from our bore hole. Water came out quite well and I had it under control then it went wooosh. Pointed pipe and jet of water went half way across field. Got a little wet fitting that new tap.
21-02-2010 #6Top Plumbing Forum Contributor
- Mar 2008
- 464
- Thanked 8 Times in 8 Posts
We had to change a stop cock in a stable block recently, no one had a clue where the supply might be or how/if it could be shut off, in the end it was easier to do it live rather than spend hours searching the farmyard. Wouldn't want to do it under that sink though.
21-02-2010 #7Plumbers Arms member
- blackpool
- 2,139
- 4
- Thanked 10 Times in 8 Posts
3/4 female cap end required as stated above. easy to put on, ask for a rubber washer inside, that way you could probably do it with no tools, screw it in hand tight!
good luckShaun, GS 233006, Engineer 2485197
24-02-2010 #8ilovemyhomeGuest
Hi all
Thanks for your replies. I went for the valve option and was recommended to use a seal thread because the valve didn't come with a washer. So i wrapped the tape around the end about 4 times (as advised by the chap in the store) and then fitted the cap and tightened with a wrench.
There is stil a very slight leak, that has reduced over the last 2 days, now it's only dripping a tiny amount, about a quarter cup over 2 days.
Will it eventually stop, or should i try wrapping more thread around the pipe and get someone stronger than me to tighten the cap???
Thanks again!
24-02-2010 #9UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
Try again with more tape. More tightening might create a leak somewhere else.
24-02-2010 #10UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
go and buy a 15mm compresion cap remove the nut and ring from the cap as your going to reuse the nut and ring thats on the valve turn of the water undo the valve fit cap onto existing nut tighten job done
this is best as its possible the leak is from the spimdle of the valveLast edited by stevetheplumber; 24-02-2010 at 10:47 PM. Reason: Automerged Doublepost
25-02-2010 #11Steady Plumbing Forum Contributor
- Jan 2010
- 222
- Thanked 5 Times in 5 Posts
your 3/4 brass cap should do. put in a 3/4 tap washer into it befor screwing on. im asked to blank these off everyday when i work in empty housing association flats.
Crimped copper pipe fittings
By Renewable M in forum Fittings & PipesReplies: 16Last Post: 27-02-2012, 01:14 PM -
central heating plan
By jbolland in forum Central Heating ForumReplies: 16Last Post: 19-10-2011, 11:55 AM -
Corroded Pipe?
By Monkfish in forum Central Heating ForumReplies: 7Last Post: 10-02-2010, 09:18 AM -
soldering Copper to chrome pipe
By ParrDi Gras in forum Central Heating ForumReplies: 9Last Post: 08-02-2010, 09:02 AM -
blocked sink...
By shaneo85 in forum Plumbing ForumReplies: 15Last Post: 10-12-2009, 11:21 AM
what is it ?
8 Minutes Ago in General Off-Topic Chat
