Results 1 to 13 of 13
Plumbing & Plumbers Forum - Shower pressure
Shower pressure
Discuss Shower pressure in the Plumbing Forum at Plumbers Forums; I have just fitted a Triton 9.5kw shower upstairs. The pressure is not good and the shower is switching from hot to cold frequently. There is no water tank in ...-
20-02-2010 #1Reggie2004Guest
Shower pressure
I have just fitted a Triton 9.5kw shower upstairs. The pressure is not good and the shower is switching from hot to cold frequently. There is no water tank in the house so it runs of a rising main. Given the poor pressure can I fit a pump 1-1.4 bar to improve the pressure?
Regards Reggie
20-02-2010 #2UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
Re: Shower pressure
No. Should be fed purely from the rising main.
Check your feed into the house.
Do you have a FULL BORE isolation valve onto the shower supply? Are your mains stopcocks (inside and outside) FULLY open?
21-02-2010 #3Reggie2004Guest
Re: Shower pressure
Feed to house is fully open and the shower has a standard 15mm isolater valve. The water board state that they are only responsible for the supply to the kitchen tap and that is OK. However, I am pretty sure it is less than 2.4 bar. The central heating system only builds up pressure to just over 2 bar. If I measure the pressure up stairs and it is less than 1 bar can I fit a pump?
21-02-2010 #4Top Plumbing Forum Contributor
- Jan 2010
- 323
- Thanked 11 Times in 11 Posts
Re: Shower pressure
no you cant it could be a blockage somewhere or an appliance ie washing machine dishwasher on that could affect pressure needs investigating
21-02-2010 #5Plumbing Forum Contributor
- Dec 2009
- Newmains
- 71
Re: Shower pressure
If you have a standard isolation valve then you do not have a full bore as WHPES rightly says. Check the installation instructions for minimum pressure for shower. If you have 2.4 bar as you say, you should also have this to the shower. If not then investigate why.
Cheers
jack
22-02-2010 #6Reggie2004Guest
Re: Shower pressure
No blockage to be found. Only have washing machine and that is off. Seems to be just poor pressure. The rising main tap presssure is the same as the others next door. we all have poor pressure upstairs being on top of a hill. The shower works OK in the summer and I thought a higher kw shower would solve the problem. TIA Reg
22-02-2010 #7Plumbers Arms member
- Feb 2009
- Essex
- 2,450
- 36
- Thanked 167 Times in 131 Posts
Re: Shower pressure
Your isolator valve, is it the type that you turn the centre with a screw driver?
If it is then its NOT a full bore isolation valve, change this and it will help.
22-02-2010 #8Plumbing Forum Contributor
- Dec 2009
- Newmains
- 71
22-02-2010 #9Reggie2004Guest
Re: Shower pressure
Thanks guys
22-02-2010 #10UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
Re: Shower pressure
2.5 bar should be enough. It may be your available flow rate which is a problem.
If all else fails you could change your shower unit to either a thermostatic mixer from your DHW and CW header tank, or fit a header tank and a Mira Elite pumped electric shower.
You cannot fit a pump onto a supply from the rising main.
22-02-2010 #11
22-02-2010 #12Reggie2004Guest
Re: Shower pressure
LOL....
I have bought one and will fit it tomorrow and see if it makes a difference.
27-02-2010 #13Reggie2004Guest
Re: Shower pressure
All is OK inasmuch as the shower is working. If anyone switches on a tap or flushes the toilet a loud noise is heard coming from the shower. My displeased daughter....
Thanks to all who assisted me. Reg
Shower pump Hot pressure not good, cold pressure good.
By Dannav in forum Central Heating ForumReplies: 5Last Post: 20-02-2010, 06:40 PM -
Shower pressure problems - pump + essex flange still no luck
By BBunter in forum Bathrooms, Showers and WetroomsReplies: 6Last Post: 04-02-2010, 09:56 PM -
Increase shower pressure in rented accomodation
By RichH in forum Bathrooms, Showers and WetroomsReplies: 3Last Post: 03-01-2010, 07:51 PM -
Could somebody help me please ? Water pressure with shower attachment problem
By Bernie in forum Plumbing ForumReplies: 9Last Post: 11-11-2009, 02:16 PM -
No pressure from shower with a megaflo
By adamrt in forum Bathrooms, Showers and WetroomsReplies: 2Last Post: 13-10-2009, 11:35 AM
i'm too pretty to work
8 Minutes Ago in General Off-Topic Chat
