Plumbing & Plumbers Forum - Help please pressure drop
Discuss Help please pressure drop in the Plumbing Forum at Plumbers Forums; Evening all, I have a Potterton Performa 28, 95% plumbed with JG Speedfit the system is 8 years old. Over the past few weeks the system has been losing pressure, ...-
20-02-2010 #1New to Plumbing Forum
- Jan 2010
- 14
Evening all,
I have a Potterton Performa 28, 95% plumbed with JG Speedfit the system is 8 years old. Over the past few weeks the system has been losing pressure, done the usual of checking the rads for corrosion, rad valves all ok, lifted the inspection hatches and checked the manifolds all ok. no visible water marks on ceilings however their was black water mark stains in the downstaires hallway leading to a shower room. the flooring is weyroc throughout the house. I remember Teeing off the hall rad to feed the shower room other than these two Tee offs there are no more joins between the manifolds and the rads. So cut a channel in the weyroc
1ft x 8ft found nothing polystirene and plastic underneath also dry.
Boiler loosing between .5 and .75 of pressure overnight. filled the system again this morning 1.5 bar by mid afternoon had dropped to 1.2 bar the heating was not on. Help!!!!!!!!!!!!! new carpets coming on wednesday.
20-02-2010 #2UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,155
Re: Help please pressure drop
Have you checked the expansion vessel and pressure relief valve? If the air has leaked out of the expansion bladder, water may be being lost as it expands.
20-02-2010 #3New to Plumbing Forum
- Jan 2010
- 14
Thanks WHPES,
This was checked on Tuesday and set at 1.5 bar, have not checked it since.
20-02-2010 #4UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,155
Put something under the oultet which will catch anything dripping and let you know.
20-02-2010 #5New to Plumbing Forum
- Jan 2010
- 14
Sorry WHPES,
Forgot to say I uncoupled the pressure relif pipe put newspaper under the boiler no leaks news paper dry.
20-02-2010 #6uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,567
- 836
- Thanked 1,284 Times in 1,225 Posts
also the o rings on the heat exchanger of the performa go bang around this age but its probably the expansion vessel if its the o rings they cost £2 each and are a doddle if you know how to do them on the performa remove the top plate behind the boiler[4 screws] looking at the red disc[the expansion vessel]remove the dust cap and blip the shrader valve if no air in there re-presureise to 1 bar with a bike pump but you must drain the boiler to do this,as you will get a false reading if when you blip the shrader valve you find water the expansion vessel is toast and you need a new one of course this may also be the case if the membrane loses pressure again after you check it
GASMAN
20-02-2010 #7New to Plumbing Forum
- Jan 2010
- 14
Thanks gas man,
not thought about that will give it a go on monday.
Vented / Unvented Mains pressure system
By phatz in forum Central Heating ForumReplies: 3Last Post: 14-07-2009, 05:49 AM -
will one way valve cause pressure drop
By AJ16 in forum Plumbing ForumReplies: 3Last Post: 04-05-2009, 05:06 PM -
gravity HW & mains CW mixer tap problem
By MarkB in forum Valves & TapsReplies: 7Last Post: 23-03-2009, 11:51 AM -
Pressure drop
By meditek in forum Central Heating ForumReplies: 1Last Post: 08-02-2009, 06:34 AM -
Pressure drop
By prodrive305 in forum Central Heating ForumReplies: 1Last Post: 04-01-2009, 04:04 PM
To bung or not to bung
