Plumbing & Plumbers Forum - Shower / Hot water probs
Discuss Shower / Hot water probs in the Plumbing Forum at Plumbers Forums; My shower is not running as hot as it should, (thermostatic), and nor are the upstairs taps although the downstairs ones are fine. The combi is on its highest heat ...
    Oct 2007
    25
    Default Shower / Hot water probs
    My shower is not running as hot as it should, (thermostatic), and nor are the upstairs taps although the downstairs ones are fine. The combi is on its highest heat setting.
    Can anyone help?
    Banned
    Jul 2009
    North Devon
    1,889
    Default Re: Shower / Hot water probs
    Quote Originally Posted by a9blue View Post
    Can anyone help?
    Run the upstairs taps more slowly to reduce flowrates and allow the combi to heat up more, might help. If it does then you can try running the shower at a lower rate, and or try adjusting the thermostatic valve (look at the manufactureres web site for instructions how to) Could be your pipe run is a bit long to upstairs or the flow rates are to high. You may need a restrictor in the combi cold feed in to keep flow rates down, check your installers manual re pressures/flow rates
    Oct 2007
    25
    Flow rates are right because a regulator was fitted, and shower has been working fine till now.
    The hot water tap near to the combi gets up to temperature when fully opened, but the shower and upstairs tap seem to be getting steadily worse.
    Is it possible that the diverter valve is not working properly and would a chemical flush help?
    Excuse my ignorance.
  1. central heating and hot water not working again..
    By mad_cereal_love in forum Central Heating Forum
    Last Post: 02-02-2010, 08:47 PM
  2. Another Mira shower problem
    By davemazo in forum Bathrooms, Showers and Wetrooms
    Last Post: 17-01-2010, 01:24 PM
  3. Lack of Hot water to shower!
    By jaw in forum Plumbing Forum
    Last Post: 17-01-2010, 09:36 AM
  4. Hot Water only luke warm
    By baglartimus in forum Plumbing Forum
    Last Post: 07-01-2010, 11:47 AM
  5. Bungalow with requirement for instant hot water and more water pressure in bathrooms
    By David Salter in forum Bathrooms, Showers and Wetrooms
    Last Post: 06-10-2009, 11:56 PM
