Hello everyone.
This is my first post and I need some good, reliable advice on this
Have been in my 'new' house for approx 6-yrs now but water bills for neighbours houses are all lower than mine. Have now checked out water meter and when stopcock turned off, meter stops (as it should) but when stopcock opened, small 'arrow' in middle occasionally jumps a bit, rotating round in very small steps.
There is no water demand in the house, have switched off central heating system, switched our water softener into bypass mode but still the meter registers a leak somewhere.
I then checked the WCs and have noticed that in three of the four pans, there is a minute trickle of water running down the back of the pan!
To prove it, I wiped the pan dry using a cloth and checked again 15 mins later - sure enough, a slight trickle or weep of water!
These WCs have had no repairs or work done to them since the house was built, so we have never ever noticed this.
What is the best fix for this - replace the siphon/valve unit inside? Or, strip it out, clean thoroughly and relocate using sealant?
Could I claim for the poor installation from the builder - we have found lots of poor workmanship throughout the house - the house was built by the No.1 UK House builder....apparently?
Please can you offer me your best advice with this and I want to get the leaks fixed to reduce my annual bill!
Many thanks.
