Results 1 to 12 of 18
Plumbing & Plumbers Forum - Ideal Logic 24 plus combi boiler says ignition lockout but no fault code
Like Tree7Likes
Discuss Ideal Logic 24 plus combi boiler says ignition lockout but no fault code at UK Plumbers Forums; Hello, i need some some advice please. I have an an ideal logic 24 plus combi boiler, it's had problems for a couple of months saying flame loss and not ...
    Feb 2015
    Default Ideal Logic 24 plus combi boiler says ignition lockout but no fault code
    Hello,
    I have an an ideal logic 24 plus combi boiler, it's had problems for a couple of months saying flame loss and not working, it has to be reset several times before it will work, my landlord had a plumber come out who reset it and said it was working fine and that it was just the weather and that was it.
    Its been off for over a week now, I have no heating and no hot water, I have two young children and it's a nightmare.
    the LLs plumber will only come out if I tell him what the problem is so that he can decided if it needs fixing, it's a two hour round trip for him coming from the nearest city and he doesn't want to come out several times so wants me to give him the fault code so that he can get any parts and fix it in one trip.
    The problem is that the display only says "ignition lockout" "1, check other gas appliances are working" "2, reset boiler"
    The plumber will not come out unless I give him a fault code because "it could be nothing and I don't want to waste my time coming out if it is not faulty" is what he said.
    The he landlord will only use him so I can't get anyone else.
    i don't know what to do, I have tried googling but I can't find anything, I really need advice from experts.
    Thanks.
    jtsplumbing's Avatar
    Tavistock. Devon
    4,844
    Default Re: Ideal Logic 24 plus combi boiler says ignition lockout but no fault code
    Take it you have checked that the water pressure is ok, that's about all we can tell you, But if this is locking out all the time then there is a fault within the boiler, is the 'Plumber' that calls Gas Safe Registered ? You need to ask ! Landlord has a duty of care to provide you with heat & hot water, Contact landlord and tell him it needs sorting ASAP, This boiler has a 7 year warranty ask him to call out manufacture
    Feb 2015
    Thank you for replying.
    The water pressure is 1.5 so is ok.
    The boiler is only 5 years old.
    The plumber bed does the gas safety check so he must be registered.
    He seems like a nice enough man, the problem is that because he lives 45 miles away he doesn't like to travel out here as he doesn't get paid for the traveling time only the time he is actually working, so it means he is losing two hours where he could be working and earning, this is why he doesn't want to waste his time coming out here if it's only a simple fault or if it will need parts.
    Is there any way to get the boiler to display the fault code?
    thanks.
    Tavistock. Devon
    4,844
    Boiler has a fault, still 2 years left on warranty , get land lord to call out Ideal, what's the point of having a plumber who wont travel, landlord using him cos he's cheep There is a way to get into fault code but that's for service engineers only CALL OUT IDEAL
    IDCHAPPY likes this.
    Feb 2015
    I think you are right, he uses him because he is a friend/they have a financial arrangement.
    I have called ideal, the person I spoke to was nice a somewhat helpful, he basically said on this model 'ignition lockout' is the code, there is no more to it, he also said that it would have 5 years warranty so would probably have expired by now, he checked but it was not registered anyway.
    I called the plumber and explained the code and he said "that's ridiculous, so I'll have to go out and but one of everything then just in case it needs it"
    he then said he won't be able to come out until next week but will have to call the landlord and talk to him about it first.
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    8,105
    You have a right to expect hot water and heating under the terms of letting, 5 days is more than enough time to allow, Sounds to me like the LL plumber hasn`t got a clue with the boiler. Contact the LL and tell him enough is enough and if you have to get someone else in then it comes out or the rent money!
    jtsplumbing likes this.
    IDCHAPPY's Avatar
    Jul 2011
    Edinburgh
    4,116
    The plumber sounds a right hoot
    Go on, give us a like on Facebook https://www.facebook.com/pages/Chaps...4716163?ref=hl
    Leo21's Avatar
    Feb 2012
    9,267
    The arrangement between the landlord and the plumber isn't your problem, tell him that. Also tell him your taking advise of the issue isn't sorted post haste. It's just not reasonable.
    Don't take it personally, I'm always like this.
    Tavistock. Devon
    4,844
    You just know he's going to turn up and start throwing parts at it, Have a look on your Gas safety certificate and see if he's put his gas safe number on it , then check it on G/Safe website,
    rpm
    rpm is offline
    Member rpm's Avatar
    8,105
    Boilers not registered so doubt if the plumber is either.
    SimonG likes this.
    Tavistock. Devon
    4,844
    Tell him you are getting Ideal out to fix boiler & deducting cost from rent, Proberly work out more cost effective as don't think "Plumber" knows what he's on about, if you speak to him ask him how he would like it without heating in currant weather conditions.
    rpm likes this.
    Feb 2015
    I've checked the gas safety certificate (which was only done recently) and checked the numbers against the gas safety website.
    The registered business number is coming up but the plumbers gas safe registered engineer number is coming up as "Engineer is not current."
  1. ideal logic 30 combi boiler F1 fault
    By bodypiercedmale in forum Central Heating Forum
    Last Post: 07-11-2014, 10:56 PM
  2. Replies: 3
    Last Post: 01-11-2012, 08:31 AM
  3. Ideal Logic 30+ "ignition lockout" ??
    By yelf in forum Central Heating Forum
    Last Post: 29-03-2011, 06:29 PM
ideal logic combi 30 ignition lockout
ideal boiler ignition lockout
ideal logic plus ignition lockout
logic combi 24 ignition lockout
logic boiler ignition lockout
