Hi folks, a quick question about moving a gravity fed cylinder from airing cupboard to the loft space. Height is going to be an issue with the cold water storage tank as it's at maximum height at the moment and when the cylinder is moved it will be just above top of cylinder. I presume this will mean pressure will be very poor. Could i pressurize the system or how would this work? I'll be getting a lot of work done in the house so re-routing pipework won't be an issue. I'm hoping to arm myself with some knowledge before i call in a plumber. Cheers in advance
