Plumbing & Plumbers Forum - removing whb and rad
Discuss removing whb and rad in the Plumbing Forum at Plumbers Forums; hello looking for clear picture. got to take out and replace a whb(no service valves) and replace a radiator, the system is running off a combi boiler, if i turn ...-
15-01-2010 #1Steady Plumbing Forum Contributor
- Dec 2009
- richmond nyorks
- 180
- Thanked 1 Time in 1 Post
hello looking for clear picture. got to take out and replace a whb(no service valves) and replace a radiator, the system is running off a combi boiler, if i turn off the water at stop cock and drain taps, then release the pressure at the prv will this allow me to remove the items above. what pressure do i lower the prv to.
15-01-2010 #2UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
- Thanked 676 Times in 610 Posts
Re: removing whb and rad
Usually all that's needed is to turn the stop valve off and turn the boiler off at the wall and a towel if you want everything totally dry.
15-01-2010 #3Steady Plumbing Forum Contributor
- Feb 2009
- Wales currently & proud to be English!
- 115
what is a WHB?
15-01-2010 #4
15-01-2010 #5Steady Plumbing Forum Contributor
- Feb 2009
- 115
Do you know, the penny just dropped and I came back to answer my own question and take the p### out of myself when kirkgas has answered for me! Cheers kirk - you da man.
15-01-2010 #6Plumbers Arms member
- Oct 2009
- north wales, cheshire, shropshire
- 1,205
- 66
- Thanked 41 Times in 41 Posts
not changing the valves no ?
if you do release the prv then it may not re-seal, judging by your q's replacing a prv would be out of your scope, its rather worrying your doing paid jobs and you dont know how to drain a combi matey least your coming on here to check thoughLast edited by moony; 15-01-2010 at 09:00 PM. Reason: Automerged Doublepost
15-01-2010 #7UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
I thought WHB was in reference to a bit on the side.
As in a shriek ... "Wife's Husband Back!!"
HALL of SHAME PHOTo`s
2 Minutes Ago in General Off-Topic Chat
