Results 1 to 6 of 6
Plumbing & Plumbers Forum - UFH manifold thumping noises
Discuss UFH manifold thumping noises in the Plumbing Forum at Plumbers Forums; I am experiencing thumping noises for 10 to 15 seconds as the thermostatic valves begin to open on one of the manifolds in my home underfloor heating system. The system ...
    Pfanatic
    Default UFH manifold thumping noises
    I am experiencing thumping noises for 10 to 15 seconds as the thermostatic valves begin to open on one of the manifolds in my home underfloor heating system. The system is 6 years old and this is a new phenomenon. I also get a single thump immediately after the demand via the bedroom stat ceases. Both the manifold pump and motorised valve seem to be working OK and there is no air in the system. Any ideas?
    Cds
    Cds is offline
    Plumbing Forum Contributor
    Worcester
    97
    Default Re: UFH manifold thumping noises
    Is it single thump or a series of thumps?
    Renewable M
    try turning the pump speed down one, see what occurs.
    Is the system open vented?
    Then I (and others) may just have an answer.....
    Pfanatic
    It's a series of thumps as the thermoststic valves open and a single thump when the bedroom stat switces off. Also it does not happen all the time, mostly at night when heat demand is high but I noted last night that there was no other demand at any of the other 3 manifolds at the time so I assume it's a high flow issue. I will turn down the pump at the manifold in question to it's lowest setting and see what happens.
    Pfanatic
    Turned the pump down to lowest setting. Still getting seies of thumps when thermostatic valves open and single thump when demand stops. Have also set the electrically operated valve to manually open all the time with same result. This problem is confined to only one manifold out of four.
    System has automatic venting at several points.
    Quote Originally Posted by Cds View Post
    Renewable M
    I could be wrong, it sounds like a flow issue. You have multiple manifolds, probably not balanced, and I wonder what size pump between boiler and manifolds.
    Can't say anything else without getting stuck in on the job.
    Hope you get it sorted
    oh and if it's a sealed system, make sure your pressure isnt too high.
  1. Salamander shower pump thumping
    By masterofnone in forum Bathrooms, Showers and Wetrooms
    Last Post: 10-01-2010, 05:08 PM
  2. Gate Valve Mains Pressure Manifold
    By DazJWood in forum Valves & Taps
    Last Post: 16-12-2009, 09:15 PM
  3. Size of pipework and need for manifold
    By paul123 in forum Central Heating Forum
    Last Post: 23-11-2009, 01:18 PM
  4. Adding a UFH zone to a Y Plan system
    By Rhodp in forum Plumbing Forum
    Last Post: 16-07-2009, 08:14 PM
  5. replacing manifold help
    By gingerbloke in forum Plumbing Forum
    Last Post: 23-11-2008, 05:26 PM
underfloor heating manifold noise
underfloor heating banging noise
noise from underfloor heating
central heating manifold noise
noisy underfloor heating manifold
under floor heating making a thumping sound
