Results 1 to 6 of 6
Plumbing & Plumbers Forum - Can I take two feeds off my Monsoon 2 twin?
Discuss Can I take two feeds off my Monsoon 2 twin? in the Plumbing Forum at Plumbers Forums; Hi, I have a Monsoon 2 twin (2 bar) which is pumping hot and cold water to our top floor shower. I've been renovating our middle floor bathroom. The old ...
    sanderr2
    Default Can I take two feeds off my Monsoon 2 twin?
    I have a Monsoon 2 twin (2 bar) which is pumping hot and cold water to our top floor shower. I've been renovating our middle floor bathroom. The old bath had traditional taps with separate hot and cold and the gravity fed water gave sufficient flow to fill the bath (using the maths I think I'm getting about 0.5 bar). As part of the poncy new bathroom, I have some designer mixer taps which need at least 1 bar and the flow with the gravity feed is, well, "pants". At 3 bar the taps will produce 20l / min.
    The question is the title really. Can I take a T off the pumped feed for the upstairs shower and use this for the poncy taps? Presumably if both the show and the bath were running at the same time (blue moon) I would only get 1 bar at each...
    Thanks in anticipation and apologies if this should have been posted in the wet room forum,
    Rob
    Cds
    Cds is offline
    Plumbing Forum Contributor
    Worcester
    97
    Default Re: Can I take two feeds off my Monsoon 2 twin?
    I have a Monsoon pump running hot & cold water to a bathroom with bath & shower and an en-suite with a shower as well as hot ton the kitchen & utility. You will get a drop in performance if both are running but it should not be a problem.
    Aug 2008
    1,529
    Hi Be mindful of any scalding that could take place when cold bath tap was turned on whilst the shower was being used. Good Luck
    sanderr2
    Great - thanks - that's good to know.... Rob
    Cds
    Cds is offline
    Worcester
    97
    justlead1 I can get SWMBO to do a dance if I play with the cold tap!
    sanderr2
    Hi, the upstairs shower has a thermionic (?) mixer valve so presumably this will prevent scolding by throttling back the hot supply in the event of someone running the cold bath tap?
  1. Twin flued boiler i.e. Keston alternative
    By highland in forum Central Heating Forum
    Last Post: 23-12-2009, 09:17 PM
  2. Twin flued boilers i.e. Keston
    By highland in forum New Member Introductions
    Last Post: 18-12-2009, 02:55 PM
  3. Twin impellor pump
    By peter1958 in forum Plumbing Forum
    Last Post: 09-11-2009, 07:49 PM
  4. twin cylinder setup
    By Jimbob in forum Central Heating Forum
    Last Post: 30-09-2009, 07:47 PM
  5. Replies: 16
    Last Post: 07-09-2009, 05:06 PM
monsoon mixers forum
